Cisco ASR1001 HX in rommon> cannot get to boot correct image
Daniel Smith
I have an ASR1001HX that has the correct code on bootflash:, but there is an image I put on this device for an ASR (asr1001x-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin ) before I remembered/realized it was an HX. So it keeps trying to load that when coming out of rommon>. Here are some commands I have done:
rommon 10 > dev
Devices in device table:
id name
bootflash: Internal flash drive
usb0: External USB drive 0
usb1: External USB drive 1
rommon 11 > dir usb0:
Please reset before continuing
rommon 12>
rommon 12 > dir bootflash:
rommon 14 > boot bootflash:asr1000-universalk9.16.06.01.SPA.bin
Please reset before booting
rommon 15 > reset
Resetting .......
but it will still find the wrong code in bootflash instead of the one I specified....help!
PK99
Not sure if this works on ASR-1000 but for the sake of trying can you try
boot bootflash:IOS/packages.conf
balaji.bandi
Try format the USB Fat 32 and copy the image to USB  - ( Make sure this is not USB 3.0 - some time USB3.0 not going to work)
when you issue dir usb0: or usb01:  you should able to see the image, if not it not going to work.
copy usb0: or 1: to flash: (before copy check the flash has any images : dir flash:
https://www.cisco.com/c/en/us/support/docs/routers/1000-series-routers/15075-recovery-c1000.html
BB
Leo Laohoo
In ROMMON, delete the offending file:
delete bootflash:asr1001x-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin
Then reboot the router.
Post the entire boot-up process because I suspect the file you're trying to boot is corrupt.
NOTE:  Please note the hard-to-find ROMMON Release Requirement Matrix.
