EIGRP: Advertising Specific /32s from a /24 Network
bocarrier
Hi -
I have a situation where I have to use EIGRP to advertise a /24 (1.1.1.0/24) out router A to the WAN while some specific devices on that network (1.1.1.123/32, 1.1.1.234/32) have to be advertised out router B to the same WAN. Any ideas on how to do that? All help would be greatly appreciated.
-Bob
Hello, you can use leak-map :
http://goo.gl/JMhcF
For this to work the host routes you want to leak needs to be in the routing table so you need to create static routes to the hosts.
You also need to make sure this host routes are not redistributed but only leaked to the WAN because else router A will send traffic destinated for that hosts to router B
Thanks for the info. I'll do some research and test it in the lab.
- Bob
