EIGRP default router propagation
sqambera
I am doing the following configuration on my router in order to propagate a default route from itself onto the neighbour router.
(conf)#router eigrp 1
(config-router)#default-information out
(config-router)#network 10.1.1.0 0.0.0.255
(config-router)#no auto-summary
whereas on the neighbour router (where I want to get the default route) following configuration has been done:
(config-router)#default-information in
EIGRP adjency has already been created between the two routers but I am unable to get a default route through eigrp. Please help. Thanks.
8 Replies 8
royalblues
Level 10
Level 10
Friend,
You do not need the default-information command to propogate a default route in EIGRP.
Add a default route on the router one.
Redistribute this static route in EIGRP and the neighbor should be able to see it
ip route 0.0.0.0 0.0.0.0
(config-router)#redistribute static
The default-information-originate is used in OSPF
HTH, rate if it does
Narayan
Thanks for the reply. Won't this redistribute all the static routes of my router into EIGRP? What can I do to only redistribute the default route?
Also, if for example ospf is also running between the two routers, will a default route being redistributed into eigrp and propagated to neighbour will take place of OSPF default route, that has been generated by "default-information-orignate" in ospf configuration and I can see it on my second router with *E2?
Yes the "redistribute static" command will redistribute all your static routes defined on that router into EIGRP.
If you don't want that you can use a route-map to allow only those static routes you want into EIGRP eg:
router eigrp 20
redistribute static route_map default_only
access-list 1 permit 0.0.0.0
route-map default_only permit 10
match ip address 1
Jon
rajinikanth
Level 3
Level 3
Hi ,
You can also use this method on your router1
to propagate default route.
(config-router)#default-network 10.1.1.0
now your router2 sees a default network with next hop of Router1
the other method is already been told by royalblues
Hope this helps
RAJ
the method which RAJ is talking about is indeed another option but it's very hard to get is work right with IGRP & EIGRP
u can propagate default routes by 3 ways
1. by using ip route [but u need to use the redistrubute command when making use of the ip route command. [!!!can' t use IGRP with this command]
2. By using the default-network command [but u need to add the network with as classfull cuase this is a classfull command. [!!!can't use OSPF & ISIS with this command]
3. By using the default-gateway commmand [when making use of this command ip routing must be disabled
ciao flash
What about if we do the following:
(config)#router eigrp 100
(config-router)network 10.0.0.0
(config)#int s0/0
(config-if)#ip add 10.1.1.1 255.255.255.0
(config-if)#ip summary-address eigrp 100 0.0.0.0 0.0.0.0
Does it also has the same effect of propagating the default route or does it make any difference?
Thanks.
You are correct, this is also a method to propagate default route via summary address command.
Raj
This is a good way to do it because you suppress all routes. Make sure you put admin distance on summary statement or you could black hole traffic. Summary route has admin distance of 5, if you are learning a default from some other source for the upstream traffic dynamically, you could send traffic to null 0. I always put a 250 just to make sure:
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 250
