EIGRP link down - want to know cause - %DUAL-5-NBRCHANGE: EIGRP-IPv4
I got this log from my core to the ISP router. Recently is 21st Feb
What could be the cause ?
Last year, around 6 times
5 Replies 5
Cristian Matei
   There is a problem with your layer1/layer2 connectivity. Sometimes there is a layer 1 issue, the physical interface goes down, sometimes it's a layer 2 issues, as EIGRP packets are no longer received and the hold time expires.
Cristian Matei.
You suspect it hv to do with layer 1 & 2.From the log, last year it happen around 7 times in between April and December.
Layer 1 i may change the cable itself
How about layer 2 ?
what can i check
It is connectivity issue between the routers, try pinging the neighbor from this router with repeat count of 1000 and check if all the ping happens, if it fails try replacing the cable.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
Hello
@Mohd Khairul Nizam wrote:
sh version
dir flash:
Kind Regards
Paul
IOS
Core SW -  cat4500e-universalk9.SPA.03.08.06.E.152-4.E6.bin"
Router - Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
