Showing results forĀ
Search instead forĀ
Did you mean:Ā
EIGRP route filter
feroz syed
Level 3
Level 3
i have one eigrp topology running with two Autonomous system (AS100 and AS200), now the  problem is am trying to block the network (4.4.4.4/32 AS100) from AS 100 to AS 200 and company policy not allowed to use Distribute-list for filtering.
i) First i try Standard ACL and apply under the interface won't work (the router has only one interface connected)
{ interface Serial1/0
ip address 123.0.0.3 255.255.255.0
ip access-group 1 in
R3#sh access-lists
Standard IP access list 1
    10 deny   4.4.4.4
    20 permit any (44 matches) }
ii) Second i try using PBR using unreachable metric (255) and applied under the interface same result won't work
R3#sh access-lists
    10 permit 4.4.4.4
R3#sh route-map
route-map FILTER_R4, permit, sequence 10
  Match clauses:
    ip address 1
  Set clauses:
metric 255
ip policy route-map  FILTER_R4 in }
iii) Third i try using Distance cmd under Eigrp config same result again not work !!
     distance 255 4.4.4.4 0.0.0.0
R3#sh ip route 4.4.4.4
Routing entry for 4.4.4.4/32
  Known via "eigrp 200", distance 170, metric 1075200, type external
  Redistributing via eigrp 200
  Last update from 123.0.0.1 on Serial1/0, 00:32:06 ago
  Routing Descriptor Blocks:
  * 123.0.0.1, from 123.0.0.1, 00:32:06 ago, via Serial1/0
      Route metric is 1075200, traffic share count is 1
      Total delay is 42000 microseconds, minimum bandwidth is 1544 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
      Loading 255/255, Hops 2
Please give me the reason for why it not work using ACL, PBR and EIGRP Unreachable Distance also give me the solution for filtering this network
Rejohn Cuares
Level 4
Level 4
Hi feroz_syed,
Items 1 and 2 are wrong usage of filtering routes. In order to get these two working you have to call access-list and route-map statements under the router eigrp process.
You almost got item 3 correct. Here is the correct config.
distance <1-255>
access-list 1 permit 4.4.4.4
distance 255 123.0.0.1 0.0.0.0 1
Another way to accomplish your requirement is to use off-set list.
router eigrp XXX
offset-list 1 in 2147483647 Serial1/0
Please rate replies and mark question as "answered" if applicable.
Thanks for your reply
i try using the same method as you mention but won't work, still the route appear in rib
R3#sh ip access-lists
    10 permit 4.4.4.4 (2 matches)
R3#
R3#sh run | se ei
ip authentication mode eigrp 200 md5
ip authentication key-chain eigrp 200 secure
router eigrp 200
network 3.3.3.3 0.0.0.0
network 123.0.0.0 0.0.0.255
metric weights 0 0 0 1 0 0
distribute-list prefix FILTER_R1_PREFIX in
no auto-summary
eigrp router-id 3.3.3.3
eigrp stub connected summary
  Last update from 123.0.0.1 on Serial1/0, 00:01:39 ago
  * 123.0.0.1, from 123.0.0.1, 00:01:39 ago, via Serial1/0
Unfortunately it is not possible to change the AD for external EIGRP routes, this method only works for internal routes.
just use a route-map for redistribution and deny this prefix.
Alain
