Enabling bfd for ospf on vlans
carl_townshend
Hi all
we have ospf setup between our sites and I am looking to enable bfd to help speed up ospf convergence.
at present we use layer 3 svi’s for the routing and not l3 physical interfaces.
Where do we put the bfd interval and timers etc? Do we enable these on the layer 3 svi I.e the vlan interface?
what are the recommended timers?
cheers
balaji.bandi
High level You can enable in SVI Interface BFD and also in OSPF config BFD interface all
Since we do not know the device model and IOS here, make sure you read the release notes for supported IOs and devices.
BB
balaji.bandi
BB
basically, you have two options: option 1 is to enable BFD under the routing process. Option 2 is to enable BFD on individual interfaces. The typical timer values are included in the examples below:
Option 1
interface Vlan 10
ip address 192.168.10.1 255.255.255.0
--> bfd interval 50 min_rx 50 multiplier 3
router ospf 1
log-adjacency-changes detail
network 192.168.10.0 0.0.0.255 area 0
--> bfd all-interfaces
Option 2
interface Vlan 10
--> ip ospf bfd
router ospf 1
