Errors on Point to Point T1's - 2811 - Timing issue?
Jake Pratt
I have an old 7200, with a T3 terminating on it.  From there, I have several Point to Point T1's through Qwest terminating at various remote locations.  At one of my locations, I have a 2811, terminating 2 PTP T1's, and I am getting lots of errors on the T1's.  This has caused some issues with data speeds and voice quality (VOIP).  I suppose there could be some QOS issues, but I'm not sure.  I have had Qwest test the lines, and they have run clean to the NIU.  They are telling me there is probably a timing issue on the router config.
I have another 2811 configured the same way, and it has no problems.  I'm not sure what I'm missing.  Does anyone have any ideas?
Jake
Here is some info from my environment:
The two channels on the T3 on my 7200 that point to these T1's and the service policy referenced:
interface Serial1/0/6:0
description Qwest Circuit ID# *********991
ip address 10.1.252.21 255.255.255.252
ip pim sparse-dense-mode
service-policy output axiom-voice
interface Serial1/0/7:0
description Qwest Circuit ID# *********992
ip address 10.1.252.25 255.255.255.252
class-map match-any voip-control
  match ip dscp af31
class-map match-any voip-rtp
  match ip dscp ef
policy-map axiom-voice
  class voip-rtp
   priority percent 33
  class voip-control
   bandwidth percent 5
  class class-default
   fair-queue
Some show interfaces of the Serial Interfaces on my 2811
Serial1/0/0:0 is up, line protocol is up
  Hardware is DSX1
  Description: Qwest PTP Circuit ID# **********991
  Internet address is 10.1.252.22/30
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 11/255, rxload 49/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 8w0d
  Input queue: 0/75/228/0 (size/max/drops/flushes); Total output drops: 1487
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/1487 (size/max total/threshold/drops)
     Conversations  0/25/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
  5 minute input rate 299000 bits/sec, 90 packets/sec
  5 minute output rate 69000 bits/sec, 29 packets/sec
     101067499 packets input, 499789832 bytes, 0 no buffer
     Received 741536 broadcasts, 14975 runts, 0 giants, 0 throttles
     19643 input errors, 19638 CRC, 0 frame, 0 overrun, 0 ignored, 487 abort
     99354543 packets output, 301350989 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Layton-2811#sho int Serial1/0/1:0
Serial1/0/1:0 is up, line protocol is up
  Hardware is DSX1
  Description: Qwest PTP Circuit ID# **********992
  Internet address is 10.1.252.26/30
     reliability 255/255, txload 16/255, rxload 8/255
  Input queue: 0/75/656/0 (size/max/drops/flushes); Total output drops: 1741
  Output queue: 0/1000/64/1741 (size/max total/threshold/drops)
     Conversations  0/29/256 (active/max active/max total)
  5 minute input rate 52000 bits/sec, 23 packets/sec
  5 minute output rate 97000 bits/sec, 72 packets/sec
     104860684 packets input, 552205434 bytes, 0 no buffer
     Received 741546 broadcasts, 15957 runts, 0 giants, 0 throttles
     20742 input errors, 20739 CRC, 0 frame, 0 overrun, 0 ignored, 535 abort
     90196734 packets output, 2306764998 bytes, 0 underruns
The majority of the config on my 2811
Current configuration : 7660 bytes
! Last configuration change at 17:02:45 MST Wed Feb 29 2012
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname *********-2811
boot-start-marker
boot-end-marker
card type t1 1 0
card type t1 1 1
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring
network-clock-participate slot 1
network-clock-select 1 T1 1/0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.9.1 10.1.9.25
ip dhcp pool ********DHCP
   network 10.1.9.0 255.255.255.0
   default-router 10.1.9.1
   option 150 ip *********
   dns-server **********
   domain-name *********
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-ni
voice service voip
fax protocol pass-through g711ulaw
h323
  h225 display-ie ccm-compatible
  call preserve
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout ntf 100
voice translation-rule 1
rule 1 /^2*/ /8015252/
voice translation-profile SRST-MASK
translate calling 1
voice-card 0
voice-card 1
archive
log config
  hidekeys
controller T1 1/0
cablelength short 133
pri-group timeslots 1-24
controller T1 1/0/0
clock source internal
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 1/0/1
cablelength short 110
interface FastEthernet0/0
no ip address
duplex full
speed 100
interface FastEthernet0/0.10
description Data Vlan 10
encapsulation dot1Q 10
ip address 10.1.8.1 255.255.255.0
ip helper-address 10.1.2.10
interface FastEthernet0/0.20
description Voice Vlan 20
encapsulation dot1Q 20
ip address 10.1.9.1 255.255.255.0
h323-gateway voip bind srcaddr 10.1.9.1
interface FastEthernet0/0.30
description Management Interface
encapsulation dot1Q 30
ip address 10.1.250.17 255.255.255.248
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling
no cdp enable
interface Serial1/0/0:0
description Qwest PTP Circuit ID# **********991
ip address 10.1.252.22 255.255.255.252
interface Serial1/0/1:0
description Qwest PTP Circuit ID# *********992
ip address 10.1.252.26 255.255.255.252
router eigrp 7
passive-interface FastEthernet0/0.10
passive-interface FastEthernet0/0.20
passive-interface FastEthernet0/0.30
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 10.1.2.24
snmp-server community *********** RO
control-plane
voice-port 1/0:23
dial-peer voice 1 pots
################ Removed all my dial peers to keep it a little cleaner on the discussion ################
dial-peer voice 109 voip
call-manager-fallback
secondary-dialtone 9
max-conferences 3 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 10.1.9.1 port 2000
max-ephones 42
max-dn 144
system message primary Your current options
transfer-pattern 9T
alias 1 xxxx to xxxx
alias 2 xxxx to xxxx
alias 3 xxxx to xxxx
translation-profile incoming SRST-MASK
line con 0
privilege level 15
password 7 ***************
login
line aux 0
line vty 0 4
privilege level 15
password 7 ****************
login
transport input telnet
line vty 5 15
privilege level 15
login
scheduler allocate 20000 1000
ntp source FastEthernet0/0.10
ntp server x.x.x.x
end
17 Replies 17
ammahend
which generation T1 card you are using ??? , kindly note following about generation 2 and generation 3 cards .
Also I see a lot of inout error which is generally an indication of physical layer issue so ensure that the line from ISP is clean and if required change the cable from router to smart jack.
VWIC generation 2:
The  Cisco 2-port VWIC2 cards can enable each port  to be clocked from  independent clock sources for data applications. This  independent  clocking capability is not supported for voice applications  or with the  Cisco ATM/Voice Advanced Integration Modules (part numbers  AIM-ATM,  AIM-VOICE-30, and AIM-ATM-VOICE-30).
controller t1 0/0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
clock source line independent <<<<<<   allowed
controller t1 0/1/0
framing esf
linecode b8zs
However Customers started facing another issue when they use VWIC2
2 ports for both voice and data, they can't use Independent clock source.
controller t1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 speed 64
clock source line independent <<<<<<  Not allowed
controller t1 0/1/0
framing esf
linecode b8zs
In this case , Cu comes with same issue,  getting Slip sec  errors, clocking errors.  Earlier Cisco use to suggest,  As a design  perspective better use 2 ports for data only and  use another card for  voice , not to get slip errors. In order to support independent clocking  for both "Data " and "voice"  on same card Generation 3 card has come  into picture.
VWIC generation 3:
The   Cisco VWIC3 cards are supported only on the Cisco Integrated Services   Router (ISR) 1900, 2900, 3900 and 3900E series platforms.
The  VWIC3 cards add enhancements to the previous generation VWIC2 cards,   including: Enhanced clocking capabilities:  The Cisco VWIC3 cards can  enable each port to be clocked from an  independent clock source for  data applications. Data ports can also be  clocked independent of voice  ports. All voice ports on the card much use  the same clock  source.Multiple data channel-groups supported per T1/E1 port
controller t1 0/0/0
framing esf
linecode b8zs
controller t1 0/1/0
framing esf
linecode b8zs
Thus VWIC3 eliminates the clocking issue compeletely.
-hope this helps-
As you can see in the config, I have the 2 point to point T1's then I have a seperate voice T1 (PRI) terminating on another card.  I don't remember for sure the version of the VWIC card on my PRI, but I think the cards I'm using for my PTP T1's are
wic 1 dsu-t1v2 cards.  Or it could be a 2-port version of that same card.  It's been quite a while since I installed the hardware, so I don't remember specifically.  Is there a command I can run that will show me hardware specifics?  I am not near the physical device.
paste the "show inventory" from the router .
-hope this helps-
Here is my show inventory:
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V07, SN: FTX1241F00U
NAME: "High Density Voice2 Network module with on board one port interface  on Slot 1", DESCR: "High Density Voice2 Network module with on board one port interface "
PID: NM-HDV2-1T1/E1    , VID: V03 , SN: FOC11463MF8
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 1 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC114836K0
NAME: "PVDMII DSP SIMM with four DSPs on Slot 1 SubSlot 2", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC114869TS
I am not on site, so I haven't checked the cables since I opened up this discussion.  However, I have checked them for similar issues recently.  They looked and tested fine.
I must admit, I don't know too much about timing or setting the clock.  A contract CCIE voice set up this router when we were upgrading our CallManager software/hardware.
This is the only thing the 7200 really says about the clock:
ip subnet-zero
no ip cef
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
controller T3 1/0
clock source line
cablelength 150
t1 1 channel-group 0 timeslots 1-24
t1 2 channel-group 0 timeslots 1-24
t1 3 channel-group 0 timeslots 1-24
t1 4 channel-group 0 timeslots 1-24
t1 5 channel-group 0 timeslots 1-24
t1 6 channel-group 0 timeslots 1-24
t1 7 channel-group 0 timeslots 1-24
t1 8 channel-group 0 timeslots 1-24
t1 9 channel-group 0 timeslots 1-24
t1 10 channel-group 0 timeslots 1-24
t1 11 channel-group 0 timeslots 1-24
t1 12 channel-group 0 timeslots 1-24
t1 13 channel-group 0 timeslots 1-24
t1 14 channel-group 0 timeslots 1-24
t1 15 channel-group 0 timeslots 1-24
t1 16 channel-group 0 timeslots 1-24
t1 17 channel-group 0 timeslots 1-24
t1 18 channel-group 0 timeslots 1-24
t1 19 channel-group 0 timeslots 1-24
t1 20 channel-group 0 timeslots 1-24
t1 21 channel-group 0 timeslots 1-24
t1 22 channel-group 0 timeslots 1-24
t1 23 channel-group 0 timeslots 1-24
t1 24 channel-group 0 timeslots 1-24
t1 25 channel-group 0 timeslots 1-24
t1 26 channel-group 0 timeslots 1-24
t1 27 channel-group 0 timeslots 1-24
t1 28 channel-group 0 timeslots 1-24
I don't know if that helps.
not that clock!
controller T1 1/0/0
controller T1 1/0/1
switch that to network.
Thanks for the reply.
I'm not familiar with the syntax?
When I do a "clock source ?", the only options that show up are "free-running", "internal", and "line".
Do I want to use "clock source line"?
I set them both to "clock source line".  I set one of them to "clock source line primary".  After doing that I cleared the counters, and it seems like they are still grabing tons of errors.
Here is a "show controller t1" a couple minutes after clearing.  Still lots of slip secs.   And you can see the clock source:
T1 1/0 is up.
  Applique type is Channelized T1
  Cablelength is short 133
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090408, FPGA: 255, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  Current port master clock:recovered from backplane
  Data in current interval (136 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 1/0/0 is up.
  Cablelength is long 0db
  No alarms detected.
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line Primary.
  Data in current interval (137 seconds elapsed):
     18 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     18 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 1/0/1 is up.
  Cablelength is short 110
  No alarms detected.
     19 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     19 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Now that you’ve reset the clocking, try and bounce the router as well. I’ve seen clock issues not get “fixed” until a hard reboot.
I just rebooted the router, and cleared the counters again.  I'm still picking up a bunch of errors:
T1 1/0/0 is up.
  No alarms detected.
  Data in current interval (143 seconds elapsed):
T1 1/0/1 is up.
  No alarms detected.
     20 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     20 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
I’ve been busy this morning and haven’t really read through all the interim emails, but as I recall you have a pair of T-1s at the branch, and a DS3 or something like that at the main location. Is that correct? If it is, then normally the telco is responsible for sending clock timing down the line. You have the branch router set to accept clock on the line. It looks like the telco is not sending clocking, or there is some other physical/logical issue. Basically, I’d bet you don’t have a Cisco problem, you’ve got a telco problem.
You are correct.  2 PTP T1's at the remote location, on the 2811, and 1 DS3 on a 7200 at my location.
I spent a bit of time talking to Qwest (the telco provider), and they say they tested everything fine back to my equipment.  I know they don't necisarilly use the same nomenclature as I do.  But they said it was probably a "timing" issue on my equipment.
also let me know if you had a chance to change the cable from router to the smart jack.
-hope this helps-
Jeff Van Houten
Level 5
Level 5
What do the controllers on the 7200 show? You're generating clocking on the 2811. Do you have clock source line on the 7200?
vmiller
Level 7
Level 7
As a general rule, only use internal timing for links like this when you are in a back to back mode, or if for some reason the LEC is just providing copper.the fact that one link does not error is more a function  of luck.
Switch both to take clock from the network.
