Errors on Point to Point T1's - 2811 - Timing issue?
Jake Pratt
I have an old 7200, with a T3 terminating on it.  From there, I have several Point to Point T1's through Qwest terminating at various remote locations.  At one of my locations, I have a 2811, terminating 2 PTP T1's, and I am getting lots of errors on the T1's.  This has caused some issues with data speeds and voice quality (VOIP).  I suppose there could be some QOS issues, but I'm not sure.  I have had Qwest test the lines, and they have run clean to the NIU.  They are telling me there is probably a timing issue on the router config.
I have another 2811 configured the same way, and it has no problems.  I'm not sure what I'm missing.  Does anyone have any ideas?
Jake
Here is some info from my environment:
The two channels on the T3 on my 7200 that point to these T1's and the service policy referenced:
interface Serial1/0/6:0
description Qwest Circuit ID# *********991
ip address 10.1.252.21 255.255.255.252
ip pim sparse-dense-mode
service-policy output axiom-voice
interface Serial1/0/7:0
description Qwest Circuit ID# *********992
ip address 10.1.252.25 255.255.255.252
class-map match-any voip-control
  match ip dscp af31
class-map match-any voip-rtp
  match ip dscp ef
policy-map axiom-voice
  class voip-rtp
   priority percent 33
  class voip-control
   bandwidth percent 5
  class class-default
   fair-queue
Some show interfaces of the Serial Interfaces on my 2811
Serial1/0/0:0 is up, line protocol is up
  Hardware is DSX1
  Description: Qwest PTP Circuit ID# **********991
  Internet address is 10.1.252.22/30
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 11/255, rxload 49/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 8w0d
  Input queue: 0/75/228/0 (size/max/drops/flushes); Total output drops: 1487
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/1487 (size/max total/threshold/drops)
     Conversations  0/25/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
  5 minute input rate 299000 bits/sec, 90 packets/sec
  5 minute output rate 69000 bits/sec, 29 packets/sec
     101067499 packets input, 499789832 bytes, 0 no buffer
     Received 741536 broadcasts, 14975 runts, 0 giants, 0 throttles
     19643 input errors, 19638 CRC, 0 frame, 0 overrun, 0 ignored, 487 abort
     99354543 packets output, 301350989 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Layton-2811#sho int Serial1/0/1:0
Serial1/0/1:0 is up, line protocol is up
  Hardware is DSX1
  Description: Qwest PTP Circuit ID# **********992
  Internet address is 10.1.252.26/30
     reliability 255/255, txload 16/255, rxload 8/255
  Input queue: 0/75/656/0 (size/max/drops/flushes); Total output drops: 1741
  Output queue: 0/1000/64/1741 (size/max total/threshold/drops)
     Conversations  0/29/256 (active/max active/max total)
  5 minute input rate 52000 bits/sec, 23 packets/sec
  5 minute output rate 97000 bits/sec, 72 packets/sec
     104860684 packets input, 552205434 bytes, 0 no buffer
     Received 741546 broadcasts, 15957 runts, 0 giants, 0 throttles
     20742 input errors, 20739 CRC, 0 frame, 0 overrun, 0 ignored, 535 abort
     90196734 packets output, 2306764998 bytes, 0 underruns
The majority of the config on my 2811
Current configuration : 7660 bytes
! Last configuration change at 17:02:45 MST Wed Feb 29 2012
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname *********-2811
boot-start-marker
boot-end-marker
card type t1 1 0
card type t1 1 1
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring
network-clock-participate slot 1
network-clock-select 1 T1 1/0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.9.1 10.1.9.25
ip dhcp pool ********DHCP
   network 10.1.9.0 255.255.255.0
   default-router 10.1.9.1
   option 150 ip *********
   dns-server **********
   domain-name *********
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-ni
voice service voip
fax protocol pass-through g711ulaw
h323
  h225 display-ie ccm-compatible
  call preserve
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout ntf 100
voice translation-rule 1
rule 1 /^2*/ /8015252/
voice translation-profile SRST-MASK
translate calling 1
voice-card 0
voice-card 1
archive
log config
  hidekeys
controller T1 1/0
cablelength short 133
pri-group timeslots 1-24
controller T1 1/0/0
clock source internal
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 1/0/1
cablelength short 110
interface FastEthernet0/0
no ip address
duplex full
speed 100
interface FastEthernet0/0.10
description Data Vlan 10
encapsulation dot1Q 10
ip address 10.1.8.1 255.255.255.0
ip helper-address 10.1.2.10
interface FastEthernet0/0.20
description Voice Vlan 20
encapsulation dot1Q 20
ip address 10.1.9.1 255.255.255.0
h323-gateway voip bind srcaddr 10.1.9.1
interface FastEthernet0/0.30
description Management Interface
encapsulation dot1Q 30
ip address 10.1.250.17 255.255.255.248
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling
no cdp enable
interface Serial1/0/0:0
description Qwest PTP Circuit ID# **********991
ip address 10.1.252.22 255.255.255.252
interface Serial1/0/1:0
description Qwest PTP Circuit ID# *********992
ip address 10.1.252.26 255.255.255.252
router eigrp 7
passive-interface FastEthernet0/0.10
passive-interface FastEthernet0/0.20
passive-interface FastEthernet0/0.30
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 10.1.2.24
snmp-server community *********** RO
control-plane
voice-port 1/0:23
dial-peer voice 1 pots
################ Removed all my dial peers to keep it a little cleaner on the discussion ################
dial-peer voice 109 voip
call-manager-fallback
secondary-dialtone 9
max-conferences 3 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 10.1.9.1 port 2000
max-ephones 42
max-dn 144
system message primary Your current options
transfer-pattern 9T
alias 1 xxxx to xxxx
alias 2 xxxx to xxxx
alias 3 xxxx to xxxx
translation-profile incoming SRST-MASK
line con 0
privilege level 15
password 7 ***************
login
line aux 0
line vty 0 4
privilege level 15
password 7 ****************
login
transport input telnet
line vty 5 15
privilege level 15
login
scheduler allocate 20000 1000
ntp source FastEthernet0/0.10
ntp server x.x.x.x
end
17 Replies 17
I think the point to point T1 is just copper.  I don't think they provide clock.  I just double checked my 7200, where the T3 terminates, and I had clock set to line there.  I think that might need to be set to internal, since it's where all my point to point T1's terminate.
I set it to clock source internal
and set my P2P T1's to clock source line
After making that change, I'm still getting lots of slip seconds.  But I haven't had a chance to hard bounce the routers yet.  I don't know that will make a difference or not.
Does that sound right to everyone?  If they are just providing copper, I should have my T3 set to internal, and all my T1's set to line?
If your T3 is functioning ok, then you are getting clocking from the provider. As far as the point to points, assuming a leased line from the telco, they should be timed from the line also.
Ashish Arora
Paste the output of
show network-clock
also try to replace the cable from the smart jack till the routers.
input errors and crc are cause of layer one issue , if  Career has alreay tested the line upto the smart jack ,then its recommended to replace cable from smartjack till the router.
as far as the serial line is concerned, there are
input errors and CRC are nearly equivalent , then its a layer 1 issue..
you just try to replace cables from smart jack upto the router.
also you can try to use a loopback connecter and check the VWIC2 module.
for creation of loopback you need to take a RJ 45 cable , twist the wire 1,4 and 2,5  ;plug this cable into serial port , set clock as internal and encapsulation hdlc, after that ping your local interface and then check the interface
see if this test go's clean..
