Extended Access-List Problem
colinmcadam
Community Member
I have tried to setup an extended access-list entry to deny traffic on port 8080 from being sent out of the router but it is not working, although the matches on the rule does go up when I try to communicate on the port. Here is what i have entered;
ip access-list extended 102
deny tcp any any eq 8080
interface serial0/0
ip access-group 107 out
Can somebody please tell me if i need to do anything else or how i can check if it is setup ok?
Many Thanks
Colin
Colin
Your original post led the discussion in a different direction when it included this:
interface serial0/0
As Narayan correctly points out the router config that you posted is using that access list as part of configuring Quality of Service not as access-group on an interface.
If you want to deny tcp traffic to port 8080 I would suggest something like this:
access-list 110 deny tcp any any eq 8080
access-list 110 permit ip any any
interface ser0/0.101
ip access-group 110 out
note that the access-group is applied on the subinterface where the IP address is configured and not on the main physical interface.
Rick
Rick
14 Replies 14
Edison Ortiz
Colin,
Unless you have a typo, the ACL on S0/0 should be
ip access-group 102 out
not
amit-singh
Level 11
Level 11
Hi Colin,
As per your config, you have the access-list configured as 102 and you have binded on the interface using access-group 107. Is that a typo mistake?
Please check it. Please send your router config and " show access-list "
HTH,
-amit singh
Colin
The previous posts indicating mismatch between the number in the access list and in the access group raise a good point. From your comment that you see the hit count in the access list go up I am assuming that it was indeed a typo in your posting.
But I believe that there is another issue with what you have posted. The access list that you show has a single line which denies tcp any any eq 8080. If that is really the entire access list then you are denying ALL traffic since anything that does not match your configured entry will match the implicit deny any any at the bottom of the access list. Either there is more to the access list that you have shown us or I do not understand how any traffic is getting through. Perhaps you can provide some more detail about your configuration.
Rick
Rick
drhague
First of all, I'm guessing that you have a typo in your post; the access-list reads 102, and the access-group reads 107. If this is not a typo, then ensure the numbers match.
The last entry in your access-list should look something like "permit ip any any", otherwise the implicit deny all will filter all traffic.
save time
Hi Friend,
As rick posted earlier, the problem seems to be with your access-list statement which is denying all traffic.
Modify your access-list in the following way
permit ip any any
interface serial0/0
It would make sense to apply the access-list inbound on the correct interface.
HTH, rate if it does
Narayan
colinmcadam
Community Member
Thanks everybody for your replys.
As you all suggest the last line was a typo and i have actually entered ip access-group 102 out.
I have not put permit ip any any into access-list 102 but have not had any other adverese affects.
If i add this will it help? Should the traffic on port 8080 not still be filtered out?
Colin
colinmcadam
Community Member
As requested here is the output from the show ip access-lists on my router;
star-derby#show ip access-lists
Extended IP access list 102
permit udp any any range 16384 32767 (92 matches)
permit udp any any precedence critical (27004015 matches)
permit udp any any dscp ef
deny tcp any any eq 8080 (122 matches)
Extended IP access list 103
permit tcp any eq 1720 any (13958 matches)
permit tcp any any eq 1720 (26400 matches)
Extended IP access list 104
permit tcp any any eq 1494 (95464127 matches)
Extended IP access list 105
permit tcp any any eq domain (8820 matches)
permit udp any any eq domain (61712 matches)
Extended IP access list 106
permit udp any any eq 88 (20135 matches)
permit udp any any eq 135
permit udp any any eq netbios-ns (367768 matches)
permit udp any any eq netbios-dgm (3254561 matches)
permit tcp any any eq 139 (1498258 matches)
permit udp any any eq 389 (10695 matches)
permit udp any any eq 445
I am new to all of this but it is worth pointing out the routers were setup by a Cisco Engineer.
Colin
colinmcadam
Community Member
A little bit more imformation for everybody.
I put the line permit tcp any any into access-list 102 and as soon as i done this it caused problems connecting to any device beyond the router.
Once removed i could connect again without any problems
Thanks again
Colin
p.s. here is the full router config
Current configuration : 2921 bytes
version 12.2
hostname star-derby
enable secret xxxx
enable password **********
memory-size iomem 15
ip subnet-zero
ip flow-cache timeout inactive 10
ip flow-cache timeout active 6
class-map match-any citrix
match access-group 104
--More-- match access-group 105
class-map match-all voice-signaling
match access-group 103
class-map match-all voice-traffic
match access-group 102
match ip precedence 4
class-map match-any windows
match access-group 106
policy-map VOICE-POLICY
class voice-traffic
priority percent 10
police cir 86000
conform-action set-prec-transmit 4
exceed-action drop
class voice-signaling
bandwidth remaining percent 2
class citrix
bandwidth remaining percent 60
--More-- class windows
bandwidth remaining percent 20
class class-default
fair-queue
voice call carrier capacity active
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 172.16.2.1 255.255.255.0
--More-- ip helper-address 172.16.1.8
ip helper-address 172.16.1.9
ip helper-address 172.16.1.10
ip helper-address 172.16.1.11
ip helper-address 172.16.1.12
ip route-cache flow
no keepalive
speed auto
interface Serial0/0
bandwidth 512
no ip address
encapsulation frame-relay IETF
ip route-cache flow
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.101 point-to-point
ip unnumbered FastEthernet0/0
frame-relay interface-dlci 101
class voice-traffic
ip classless
--More-- ip route 0.0.0.0 0.0.0.0 Serial0/0.101
no ip http server
ip flow-export version 5
ip flow-export destination 172.16.1.107 2053
map-class frame-relay voice-traffic
frame-relay cir 512000
frame-relay mincir 512000
service-policy output VOICE-POLICY
frame-relay fragment 400
access-list 102 permit udp any any range 16384 32767
access-list 102 permit udp any any precedence critical
access-list 102 permit udp any any dscp ef
access-list 102 deny tcp any any eq 8080
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
access-list 104 permit tcp any any eq 1494
access-list 105 permit tcp any any eq domain
access-list 105 permit udp any any eq domain
access-list 106 permit udp any any eq 88
access-list 106 permit udp any any eq 135
access-list 106 permit udp any any eq netbios-ns
--More-- access-list 106 permit udp any any eq netbios-dgm
access-list 106 permit tcp any any eq 139
access-list 106 permit udp any any eq 389
access-list 106 permit udp any any eq 445
snmp-server community public RO
snmp-server enable traps tty
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
Hi Colin,
Seeing your posts now, it is clear that the access-list is actually referring to a QoS configured for VoIP.
The access-list need not be applied to the interface. It is actually referenced when you configure the service policy command on the Interface.
so in your case you do not need the permit tcp any any command.
In fact you dont even need the access-list 102 deny tcp any any eq 8080
If a match is not found in your access-list then that particular traffic is not going to be prioritised
Narayan
Thanks Narayan for your reply.
From what you have said i have added the deny entry to the worng place.
I want to block traffic on port 8080 from leaving the router and thought adding it to an access-list was the correct way to do it.
can you suggest the correct way to achieve this please?
Many Thanks
Colin
Colin
interface serial0/0
Rick
Rick
Rick
Thanks for that - I have applied this and it has achieved what i wanted.
Thanks everybody for their help and applogies for leading you down the garden path as it were!
If anybody wishes to take the time to explain the difference between what i had on the extended interface and what i now have which is on the subinterface and what the two access-lists are used for that would be great - i will go and do some research now.
Thanks again
Colin
Colin
It can seem confusing when you have a main physical interface and also have a subinterface on the physical interface. But I believe that we can clear up the confusion. The main physical interface provides physical connectivity. This is where the signaling takes place. But for some media, and Frame Relay is a prime example, we may configure subinterfaces under the main physical interface. In your configuration there is no IP address on the physical interface (as is typical) and the IP address is assigned on the subinterface. If you think about it that means that there is no IP processing on the main physical interface and the IP processing takes place on the subinterface. When you think about it that way it should make better sense that you would not apply the ip access-group on the main physical interface (where there is no IP processing) and would use ip access-group on the subinterface (where there is IP processing).
Rick
Rick
