forward external dynamic ip:port to internal ip:port on isr series 1100
ino
how do i forward a port from an external dynamic ip
if some one could give me an example?
ip nat inside source static tcp 10.10.10.10 123 1.2.3.4 321
this if i am not wrong would forward calls to my external ip 1.2.3.4:321 to an internal 10.10.10.10:123 ip
how can i
dynamic_ip:321 --> 10.10.10.10:123
and for completeness
10.10.10.10:123 --> dynamic_ip:654 --> internet
10.10.10.10:123 --> dynamic_ip:what ever is free --> internet
this is my current config which works so fare
Router(config)#interface cellular 0/2/0
Router(config-if)#ip address negotiated
Router(config-if)#dialer in-band
Router(config-if)#dialer-group 1
Router(config-if)#ip nat outside
Router(config-if)#no shutdown
Router(config-if)#exit
Router(config)#dialer-list 1 protocol ip permit
Router(config)#ip route 0.0.0.0 0.0.0.0 cellular 0/2/0
Router(config)#interface vlan1
Router(config-if)#ip address 10.10.10.1 255.255.255.0
Router(config-if)#ip nat inside
Router(config)#ip access-list extended NAT
Router(config-ext-nacl)#permit ip 10.10.10.0 0.0.0.255 any
Router(config-ext-nacl)#exit
Router(config)#$ip nat inside source list NAT interface cellular 0/2/0 overload
device c1111-p4lteea
i am totally new to ios and the above config took me 2 days
so if some one could lent me a hand
cheers rick
static NAT with dynamic IP addresses (such as in your case Cellular 0/2/0 with ip address negotiated) would look like this:
ip nat inside source static tcp 10.10.10.10 123 interface Cellular 0/2/0 321
6 Replies 6
balaji.bandi
below example works for you ?
ip nat inside source static tcp 10.10.10.10 123 interface cellular 0/2/0  321
BB
ino
hmmm till now i tried with cisco packet tracer
now i took the time and tried it on an actual c1111 on the real device it accepts the command
i cant test if it works or not as there is no sim installed in the moment and i wont get to the device location till tomorrow
but it looks promising
my confusion and inability to figure it out came from the packet tracer not accepting such commands
question why cant i enter this in packet tracer (using a gi0/0/0 instead of cell)
packet tracer in general dont seems to accept an interface in this place
Router(config)#ip nat inside source static tcp 10.10.10.10 123 interfac?
% Unrecognized command
cheers rick
Packet Tracer does not feature full IOS versions, but only a subset of commands required to accomplish predetermined tasks.
The command works on every 'real' router.
balaji.bandi
i am not an expert on that tool - in the real-world it should work as expected.
or look below video may help :
https://www.youtube.com/watch?v=hGyNiveOlUs
BB
ino
have tested it
working fine
what isnt clear why
inside source --> Cellular
from a general logic this should mean if the device whit the ip 10.10.10.10 from port 123 sends something route it trough cellular 123
and not if you receive something on cell port 123 route it to 10.10.10.10
