Frame Relay QOS Config
paul.coley
I am working with 2621xm IOS (12.2(15)T10)
and I am looking for a basic QOS configuration to use so that I can prioritize traffic from my inside network to an external host IP. Below is what I think should work...please provide any suggestions/feedback.
class-map match-all CLASS-DEBIT
match access-group name Debit-out
policy-map QOSPOLICY
class CLASS-DEBIT
bandwidth 10
random-detect
ip access-list extended Debit-out
permit ip 10.200.10.0 0.0.0.255 XX.XX.XX.0 XXX.XXX.XXX.XXX
Applied to frame interface
frame-relay class QOSPOLICY
show frame pvc [dlci]
Edison Ortiz
'frame-relay class' command will reference a map-class not a class-map :)
class CLASS-DEBIT
bandwidth 10
random-detect
map-class frame-relay QOSPOLICY
service-policy output QOSPOLICY
interface sx/x
what are the show commands that can be used to see if this works?
I did a show int s0/0 and the queueing strategy is still FIFO
