When doing Frame Relay Traffic Shaping between two routers, if the following command is configured on the two routers interface support the DLCI
"frame-relay adaptive-shaping becn"
So this will enable the router receiving congestion to tell the distant end router to apply flow control on the traffic? Does any other commands need to be applied under the dlci?
