frf.16, ppp multilink and voice over ip
rabeder
hi,
i have a branchrouter over a 2mb/s connection.
this branch has voice over ip.
now i must upgrade this 2mb/s to 4mb/s.
i will do this with our provider with a second connection.
the question is:
if i bundle these 2 connection to a virtual line with ppp multilink or frf.16
is this a problem with the connectionless rtp/udp voice stream ??
- wrong sequenz at the receiver-
if yes:
what other solution has cisco for my request?
thanks
ekiriakos
I bundled in the past 6 E1's on two routers (3 on each router at each end) and run VoIP (for a call centre) with no problems at all. I used CEF to ensure per session load balancing.
E.
hi,
tanks for answer.
i think the solution to this is the per session load balancing and not using per paket balancing
