FTP passive or active
slayerhawk
Hi all. I have an issue where a 1750 using IOS 12.1.3(XT2). I have client software on the LAN side that creates an FTP connection, authenticates, then disconnects without transferring any files.
I called the company and they stated that it could be an ftp "active/passive" issue. Can anyone shed any light on why I would need to make adjustments to my config?
5 Replies 5
a.cruea1980
Level 3
Level 3
Because active FTP connections use a random port for data transfer, but passive uses port 20, if I remember correctly.
It would probably be wiser to make the clients use passive FTP than to change your router around to try and get connections through.
You've got it the wrong way around.
PASV uses a random >1024 port, while non-passive uses port 20 for data connections.
BOTH can be a pain to setup if the FTP server is unaware of being behind NAT.
Has anyone made this work? The clients on the LAN side use an active ftp session. I have used an access list that allows all tcp, ip, and udp to the host ip address.
Ooooooooops. Thanks. :)
