Healthy bandwidth utilization
vincehgov
Is there a bandwidth utilization percentage that is considered "healthy?"  We run our WAN link at 99% utilization.  The QoS should be doing its job and dropping less critical packets.
Vince
5 Replies 5
paolo bevilacqua
99 or even 100 is fine, if you can accept network slowness.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Really depends on the nature of the traffic.  Bulk data transfers that are transferred fast enough to finish within a time window are generally fine running a link at 100%.  Latency sensitive traffic, might require as little as about 1/3 utilization (not counting QoS de-prioritized latency insensitive traffic utilization).
Thanks guys.  I was just curious if it was something like CPU where you want to keep it less than 80% to protect the hardware. I was worried there was a risk of the port melting.
vince
remember, its full duplex so you have the same capacity send as you do receive.
No, there is no such risk. These are routers not combustion engines.
