Help with Cisco 2911
Jobin Varghese
Hi All,
I have this new Cisco 2911 and have a few doubts regarding the device and also require help for configuration.
I have a dedicated Internet and a VPN coming from an ISP. Terminated at our end by OFC and connected to a Cisco ME 3400. The cables run to our server room.
For the dedicated line the following details where give
IP: XX.XXX.88.5
Subnet: 255.255.255.252
                  GW: XX.XXX.88.6
                  DNS 1: XX.XXX.6.5
DNS 2: XX.XXX.57.230
For the VPN the providers gave the following details:
PE interface IP: XXX.XX.83.113
CE interface IP: XXX.XX.83.114
Vlan: 446
The present configuration on the Cisco 2911 is as follows:
Building configuration...
Current configuration : 3524 bytes
! Last configuration change at 14:13:16 UTC Thu Apr 19 2012 by xxx
! NVRAM config last updated at 14:13:17 UTC Thu Apr 19 2012 by xxx
version 15.1
hostname CORE_Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server xx.xxx.6.5
ip name-server xx.xxx.57.230
crypto pki trustpoint TP-self-signed-xxx
xxx
xxx
xxx
xxx
crypto pki certificate chain TP-self-signed-xxx
certificate self-signed 01
        quit
license udi pid CISCO2911/K9 sn xxxxxxxxx
username xxx privilege 15 secret 5 xxxxxxx
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.105
description $XXX_DIA6$
encapsulation dot1Q 105
ip address xx.xxx.88.5 255.255.255.252
interface GigabitEthernet0/2
description $XXX_LAN$
ip address xxx.xxx.6.254 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 xx.xxx.88.6
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
I have a Cisco 2911 with default ports, and intend to connect the dedicated line to G0/0 and the VPN to G0/1 and connect my G0/2 to my LAN.
  •   Is this possible on Cisco 2911 router?
  • Can someone help me with a correct configuration for the set-up?
  • I have another Point-2-Point Leased Line from a different ISP, can that be configured on the same 2911 router with addition of a WAN interface card?
Consider me an absolute novice and wanting to gain as much knowledge as possible.
Thank You.
7 Replies 7
Jobin Varghese
Anyone ? It's kind of an urgent issue. Sorry
Only six hours have passed and you already solicit to get somebody else to configure your system ?
This is freely-contributed forum, recommend that for time-bound support you purchase a contract from Cisco or other company,
Paolo I wan't complaning. I understand what you are saying. Just was expressing my point. I do understand its a freely-contributed forum, but was thinking there would be many experts here.
On a Saturday????  Are you kidding?
Contact Cisco TAC.
Sorry about that, here in Middle East its just a friday that we get as weekend.
Pawan Sharma
Hi Jobin,
Cisco 2911 have 3 giga ethernet ports by default you can use them in the following manner -
Gi 0/0 - For dedicated line
Gi 0/1 - For VPN Line
Gi 0/2 - For LAN Connectivity
for adding your point to point line to this router you will need one additional interface, For that you have various options available -
Option 1 - HWIC-1FE - One port Fast Ethernet Card - Routed
Option 2 - HWIC-4ESW - Four Port EtherSwitch card - Layer 2 but you can configure routing using SVI (This is one is a cheaper option and would also give you some additional ports for future use)
Lemme know if I could be of any further help.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
Thanks Pawan. That solves a lot of the issue regarding the hardware. Are there anymore additions that i should make with the configuration ? It doesn't seem like communicating with the Cisco ME 3400. What additionla configurations do I make for the VPN along with the configuration.
