help with ip route
flippedmedia1
We are having problems routing our 192.168 addresses to the internet. When we add a default route it works fine but pushes out through that default route. Any ideas on what we are doing wrong? We have tried 100 things but nothing seems to work:
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname gw
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface FastEthernet0/0
description 10Mbps Connection 1
ip address 64.1.147.2 255.255.255.0
ip nat outside
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
description 10Mbps Connection 2
ip address 64.2.22.166 255.255.255.252
ip nat outside
no ip route-cache
no ip mroute-cache
speed 10
full-duplex
no cdp enable
interface FastEthernet1/1
ip address 192.168.101.1 255.255.255.224 secondary
ip address 192.168.101.33 255.255.255.224 secondary
ip address 192.168.101.65 255.255.255.224 secondary
ip address 192.168.101.97 255.255.255.224 secondary
ip address 192.168.101.129 255.255.255.224 secondary
ip address 192.168.101.161 255.255.255.224 secondary
ip address 192.168.101.193 255.255.255.224 secondary
ip address 192.168.100.1 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
no cdp enable
ip nat inside source static 192.168.101.2 62.100.551
ip nat inside source static 192.168.101.3 62.100.552
ip nat inside source static 192.168.101.4 62.100.553
ip nat inside source static 192.168.101.5 62.100.554
ip nat inside source static 192.168.101.6 62.100.555
ip nat inside source static 192.168.101.34 62.100.556
ip nat inside source static 192.168.101.35 62.100.557
ip nat inside source static 192.168.101.36 62.100.558
ip nat inside source static 192.168.101.37 62.100.559
ip nat inside source static 192.168.101.38 62.100.5510
ip nat inside source static 192.168.101.66 62.100.5511
ip nat inside source static 192.168.101.67 62.100.5512
ip nat inside source static 192.168.101.68 62.100.5513
ip nat inside source static 192.168.101.69 62.100.5514
ip nat inside source static 192.168.101.70 62.100.5515
ip nat inside source static 192.168.101.98 62.100.5516
ip nat inside source static 192.168.101.99 62.100.5517
ip nat inside source static 192.168.101.100 62.100.5518
ip nat inside source static 192.168.101.101 62.100.5519
ip nat inside source static 192.168.101.102 62.100.5520
ip nat inside source static 192.168.101.130 62.100.5521
ip nat inside source static 192.168.101.131 62.100.5522
ip nat inside source static 192.168.101.132 62.100.5523
ip nat inside source static 192.168.101.133 62.100.5524
ip nat inside source static 192.168.101.134 62.100.5525
ip nat inside source static 192.168.100.201 62.100.5527
ip nat inside source static 192.168.100.151 62.100.5528
ip nat inside source static 192.168.100.216 64.1.147.216
ip nat inside source static 192.168.100.121 62.100.5529
ip nat inside source static 192.168.100.200 62.100.5530
ip nat inside source static 192.168.101.205 62.100.5526
no ip http server
no ip http secure-server
ip classless
no ip route static inter-vrf
ip route 192.168.100.0 255.255.255.0 64.2.22.165
ip route 192.168.101.0 255.255.255.224 64.1.147.1
ip route 192.168.101.32 255.255.255.224 64.1.147.1
ip route 192.168.101.64 255.255.255.224 64.1.147.1
ip route 192.168.101.96 255.255.255.224 64.1.147.1
ip route 192.168.101.128 255.255.255.224 64.1.147.211
ip route 192.168.101.160 255.255.255.224 64.1.147.211
ip route 192.168.101.192 255.255.255.224 64.2.22.165
snmp-server community 7fmiow55 RW 20
snmp-server enable traps tty
line con 0
line aux 0
line vty 0 3
line vty 4
transport input ssh
end
You can't use static routes for doing source based routing.
Try route maps as follows.
access-list xx permit ip 192.168.101.0 0.0.0.127 any
access-list yy permit ip 192.168.101.128 0.0.0.61 any
access-list zz permit ip 192.168.100.0 0.0.0.255 any
access-list zz permit ip 192.168.101.192 0.0.0.31 any
route-map internet permit 10
match ip address xx
set ip next-hop 64.1.147.1
route-map internet permit 20
match ip address yy
set ip next-hop 64.1.147.211
route-map internet permit 30
match ip address zz
set ip next-hop 64.2.22.165
ip policy route-map internet
Shijo George.
6 Replies 6
antonyjaison
Please understand the syntax for ip route command. You have to secify the destination addresses in ip route commands not your inside source network. I can see that 198.168.100.* and 198.168.101.* are your inside networks. Remove all the static routes which you added now and add a single default route to internet( because we don't know destination networks which we are going to access in intrenet). Your purpose will be solved with a default route itself..
Jaison
Jaison,
We need static routes to specify using two different ISPs for different types of traffic. We want certain subnets to push out on one interface, and other's to push on another interface.
Can you expand on why this isn't working for us with our current config?
Thanks a lot.
match ip address xx
match ip address yy
match ip address zz
Shijo George.
That worked great!
1 more question:
From 192.168.100.xxx we can't ping 192.168.101.xxx but we can ping the gateway. From 192.168.101.xxx we can ping any 192.168.100.xxx host.
How can we ping and talk to both networks?
Thanks!
Either you can define a access-list with source and destination ports and apply it on your outside interfaces or you can do a dynamic NATing and filter the souce addresses with a access-list.
Jaison
have you tryed adding 2 default routes with equal metrics, one pointing to ISP A and the other pointing to ISP B. and then specify two different NAT pool list depending on what type of traffic or ip addresses you need utilized with which ISP.
ip nat inside source list ISP A (specify the ip address you want)
ip nat inside source list ISP B (specify the ip addresses)
add the access lists to allow hosts
ip nat outside source list 1 pool ISP A (add-route)
ip nat outside source list 2 pool ISP B (add-route)
steve
s
