Help with NAT
N_Martin
I have an 837 connected to internet and LAN. The WAN interface receives an IP address via DHCP from the ISP. The LAN is on network 192.168.1.0
I want to setup NAT to redirect port 8080 on WAN interface to 192.168.1.250:80 on LAN.
Have had a play but cant seem to get it to work. Is this possible with a dynamic WAN address and can anyone advise how to to do this?
Many Thanks
dbellaze
Level 4
Level 4
Heres an example. Just replace the dialer x with the correct interface type and number.
ip nat inside source static tcp 192.168.1.250 80 interface dialer x 8080 extendable
Heres a getting started link for NAT for reference.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic8
Daniel
tekha
Level 3
Level 3
The follwing is taken from a 831 router running 12.3(8)YG1.
interface Ethernet1
ip address dhcp client-id Ethernet1 hostname :-)
ip nat outside
interface Ethernet0
ip address 10.10.54.4 255.255.255.0
ip nat inside
ip nat inside source static tcp 10.10.54.2 23 interface Ethernet1 10023
