Static NAT mapping is not working
tkalfaoglu
Hi. I thought I had this down pat, but it turns out I didn't.
This is a CISCO 3925.. Single outbound IP, and a bunch of LAN clients using
192.168.x.x
very typical setup.
NAT is working fine, except I can't allow an incoming port to be mapped.
I have a DNS server running locally at port 5333.  LAN hosts can access it, no problems.
I would like the world to access it as port 53.
My remote IP is, 193.162.105.108.  The DNS server is at 192.168.1.191
This is not working:
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.191 53 193.162.105.108 5333 extendable
ip nat inside source static udp 192.168.1.191 53 193.162.105.108 5333 extendable
interface GigabitEthernet0/1
ip nat inside
interface Dialer1
ip nat outside
ip nat enable
I also have
access list
in, but it permits both 53 and 5333 for UDP and TCP.
I'll enclose the entire file in case it helps..
Many thanks, -t
tkalfaoglu
SOLVED.. I had to to this instead of the
nat static
lines above:
ip nat inside source static tcp 192.168.1.191 5333 interface Dialer1 53
ip nat inside source static udp 192.168.1.191 5333 interface Dialer1 53
This routes ALL port 53 traffic to that one server's 5333 port.. it works!
6 Replies 6
ip nat inside source list 100 interface Dialer1 overload
Ip access-list standard 100
Deny tcp/udp 192.168.1.191 53 any
Permit ip 192.168.1.0 0.0.0.255 any
You need to
deny tcp/udp
traffic form NATing overload
By the way
dns use udp not tcp
Many thanks. When I did that, the
192.168.1.191
could not reach the internet.. therefore it was useless as a DNS server ..
Sorry' can I see your last config
tkalfaoglu
nat static
lines above:
So server ise 5333 not known port 53.
Anyway glad your issue solved
Have a nice summer
MHM
tkalfaoglu
Many thanks - there are actually TWO DNS servers running on that machine, that's why one of them is at a non-standard port..
