Routing and SD-WAN
Labels
Hi , Anyone here running MX 19.2.9 ? If so can you check the firmware version with the API ? ( getOrganizationDevices )100% of my networks migrated are showing :  "firmware": "Not running configured version", "url": "xxxxx", "details": [ { "name": "R...
Raphael_L by • Meraki Community All-Star
  • 261 Views
  • 3 replies
Hi All,I am locked out of a Cisco C8500-12X and trying to perform password recovery. I have physical/direct console access, but no CLI access because the router stops at the username/password authentication prompt.Device details:Platform: Cisco C8500...
I want to understand when migrating existing Cisco SD-WAN environment to the UX 2.0 framework (Configuration Groups and Policy Groups). This will involve moving device templates, centralized control policies, data policies, and localized policies.Con...
Iaak by • Frequent Visitor
  • 689 Views
  • 5 replies
Hello Community,Can you please help me to understand how FCS and IP checksum work? If I understand correctly, when frame is received by L2 Switch, switch checks FCS of that Frame (but only if switching mode of the switch is "store and forward", which...
Just wondering if anyone had done any testing with HTTPS inspection on MX? Interested in knowing how it impacted performance as well as any other gotcha's.https://documentation.meraki.com/SASE_and_SD-WAN/MX/Operate_and_Maintain/Content_Filtering_and_...
Trying to find out if anyone knows of the documentation that would list out differences between ACL operation on a router versus a multi-layer switch/SVI.The specific issue:  inbound ACL applied to an actual router/router interface (untagged or tagge...
jbworley by • Community Member
  • 450 Views
  • 14 replies
Hello, everyoneI have a quick question. One of the use cases for the MPLS control word is fragmentation."The fifth reason for the control word is the correct functioning of the fragmentation and reassembly of the frames. The PE routers can indicate w...
Mitrixsen by • Spotlight
  • 163 Views
  • 2 replies
HiI have two vMX-M deployed into Azure in mid 2025. They replaced an old VMX100.I am documenting procedures around DDOS and an emergency need to change the public IP of the VMX. We have Azure DDOS protection but I am tasked with planning for the very...
liamsteven by • Community Member
  • 300 Views
  • 10 replies
