Home Lab | Client Not able to reach internet
mr_Nobody
 Switch config:
ip dhcp pool Mgmt-Network
network 10.72.44.0 255.255.255.0
default-router 10.72.44.1
dns-server 1.1.1.1 1.0.0.1
domain-name example.com
lease 0 8
vlan 10
int vlan 10
 ip add 10.72.44.1 255.255.255.0
 ip nat inside
int gig1/3
ip add 192.168.0.100 255.255.255.0
ip nat outside
int gig0/0
switchport mode access
switchport access vlan 10
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 10.72.144.0 0.0.0.255
ip nat inside source list 1 interface GigabitEthernet1/3 overload
Switch:
1. Switch is able to reach internet with source vlan 10 and without source as well.
2. Switch is able to reach the PC
PC:
1. PC is getting IP address from dhcp(10.72.44.2)
2. PC is able to reach 10.72.44.1, 192.168.0.100
3. But PC is not able to reach 192.168.0.1 and internet
2 Accepted Solutions
Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Experimental Version 15.2(20170321:233949) [mmen 101]
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 22-Mar-17 08:38 by mmen
I had a closer look and wondered why it was not working. I do not recall the solution.
There is a bug in vIOS - possible solutions as below :
1. Go to switch config mode and try to remove  cef by issuing command as
config t
no ip cef
end
Then test it.
2. Other options I can think of are use the L3 Router image (rather l2 image)
BB
As I mentioned, it's a bug on the virtual image; real hardware is not an issue.
try latest vIOS or IOL image.
check my old post for reference to CEF if you like to know more :
https://community.cisco.com/t5/switching/configure-process-switching/td-p/4803272
BB
11 Replies 11
Richard Burts
What kind of switch is this? Very few Cisco switches are able to provide NAT.
Rick
M02@rt37
Do you check if nat translation is ok ?
Best regards
balaji.bandi
There is a mistake in the ACL, correct it.
to
access-list 1 permit 10.72.44.0 0.0.0.255
still issue - as other member asked what switch is this, can you post show version
BB
hello @balaji.bandi
hawk eye !!!
Best regards
mr_Nobody
@balaji.bandi
that's a typo in the access list. actualy access-list is correct
switch#sh access-lists 1
Standard IP access list 1
10 permit 10.72.44.0, wildcard bits 0.0.0.255
@Richard Burts
This lab is in Eve-NG
switch#sh ver
M02@rt37
ip nat translations
switch#ping 1.1.1.1 source vlan10
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.72.144.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 85/94/114 ms
switch#
switch#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 192.168.0.100:1024 10.72.144.1:1 1.1.1.1:1 1.1.1.1:1024
Still i am not sure the information correct.
Your output shows 144 - one of the sure its wrong.
switch#
Make sure your ACL and VLAN should either 144 or 44
start with PC can able to ping gateway, try traceroute to 1.1.1.1 show us the output ?
BB
krmp010608
ipconfig in PC, please
mr_Nobody
Packet sent with a source address of 10.72.44.1
icmp 192.168.0.100:1024 10.72.44.1:1 1.1.1.1:1 1.1.1.1:1024
config t
no ip cef
end
Then test it.
BB
mr_Nobody
@balaji.bandi
no ip cef command worked.
Thanks a lot for your help...
Would you mind explaning it, I mean how it started working after turning off cef ?
BB
