Configure Process Switching
holeman4110
Frequent Visitor
Frequent Visitor
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-120-mainline/47205-cef-whichpath.html
I found how to set Switching Method for CEF, Fast only on above doc.
For configure process Switching, should I set process switching for both inbound and outbound?
2 Accepted Solutions
for anyone else see this post
there is NO command for process switching, when you need to run process switching disable fast/cef
to check if fast/cef is enbale or disable do
show IP interface x/x
if you are virtual,  there are bugs around with IP CEF and image you using
Try vIOS and test it.
BB
36 Replies 36
balaji.bandi
It all depends on what Platform you looking to use - below document guide you what is CEF :
https://ipwithease.com/cisco-express-forwarding-cef/
More information can be find below various platforms.
https://www.cisco.com/c/en/us/tech/ip/ip-switching/index.html
BB
Joseph W. Doherty
Just curious, why do you want to configure process switching (as it's much slower, like 10x slower)?
I just wanna see how 3 kinds of switching work, since I've just started to study load balancing 🙂
Ah.
Usually how packets are switched only differs in "speed".
However, I recall "true" process switching does packet by packet LB. CEF often offers that too as an option.
BTW, packet by packet LB is often also adverse to traffic too.
as I know the process switching is default
then can change default by config
1- fast
or
2- CEF
so process switching is by default there
CEF is default(I did my lab on GNS3).
if you disable CEF are the packet forward ?
Yes
so there is default process switching  running in R
and for default CEF as I mention before there two Configurable process fast and CEF and CEF is default configurable in R
hmm... It's werid.
CEF is default is on my side.
 Maybe we have difference versions of IOS?
No,
CEF can enable in global mode and interface mode.
do
no ip cef
no ip route-cache
under interface and check
please remove solution for my this answer and select the answer with cisco slide, to be clear to all read this post later
thanks
MHM
Yeap I did it and I really appreciate all of your replies 🙂
BB
Alright. I will try with that as well. Thx for your help!
