Hot swap PA-MC-8TE1+
kokencisco
Hallo,
Can I do "hot swap" with a PA-MC-8TE1+ interface on a 7200 router?
Not sure in your country. In my country we use E1. Yes, can configure channelized E1 like previous interface E1/PRI 1200hm PA
regards,
maher
6 Replies 6
maher
Yes. Just done it today on my operational routers :). No problem at all.
Good!!! But I don't know if it is the right solution. My problem is that the interface's red led "AL" is light and I don't view the interface in the "sh run" therefore I had think to eject and plug-in the interface newly!!
For this type of card, need to enable the config.
Router#sh diag 1
Slot 1:
PA-MC-8TE1 Plus Port adapter, 8 ports
Port adapter is analyzed
Port adapter insertion time 00:02:17 ago
EEPROM contents at hardware discovery:
Hardware Revision : 2.0
PCB Serial Number : JAE073502RH
Part Number : 73-7549-02
Board Revision : A0
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : PA-MC-8TE1+
Top Assy. Part Number : 800-19387-02
Enable either e1 or t1
Router(config)#card type e1 1
then should be okay.
THANK YOU A LOT!!! I don't know anything about this!! So, i type "sh diag 2" and the result is this:
Router# sh diag 2
Slot 2:
Port adapter insertion time 19w1d ago
PCB Serial Number : JAE0826MVJ9
Board Revision : A0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 4E 41 02 00 C1 8B 4A 41 45 30 38 32
0x10: 36 4D 56 4A 39 82 49 1D 7D 02 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 50 41 2D
0x30: 4D 43 2D 38 54 45 31 2B 20 20 20 20 20 20 20 20
0x40: 20 C0 46 03 20 00 4B BB 02 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
but i don't know if I have to enable E1 or T1!!!
On this interface there is a PRI ISDN at 120Ohm....I cannot configure it because I never did it...can you help me?
Bye
regards,
maher
Hi, thanks you a lot!!!!
My contry is ITALY, Do you know what's if the standard is E1 or T1 ?
