how can I force the router to run no shutdown on interfaces after power on ?
soroushpour
balaji.bandi
if the ports are configured with no shutdown and wr in the memory, they always come up. (until i hear something different here)?
BB
7 Replies 7
you could use an EEM script such as the one below:
event manager applet NOSHUT_IF
event syslog pattern "SYS-5-RESTART"
event timer countdown time 10
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface range GigabitEthernet0/1 - 4"
action 4.0 cli command "no shut"
action 5.0 cli command "end"
Thank you
Thank you, I don't know about EEM
balaji.bandi
BB
no shutdown doesn't remain in the memory.
Can you post the device information and show version to look your confreg.
BB
You are total right, I forgot to copy running config.
