how configure a DNS relay on cisco 877
wififrance
all is in the title.
thks so much
5 Replies 5
purohit_810
Level 5
Level 5
See for DNS configuration:
in global configuration mode
ip name-server x.x.x.x
ip domain-name yahoo.com
Dharmesh Purohit
sorry
i hav already test this, it's not working the host receveid the good configuration by the dhcp server. But the dns isn't working
royalblues
Level 10
Level 10
I dont think i follow your question completely but if you are trying to resolve names you can configure name server on the router
ip name-server
http://www.cisco.com/warp/public/105/reversedns.html
With the above command the router would be able to resolve names but it will not resolve names for your clients
Narayan
paolo bevilacqua
Obtain the name servers automatically via DHCP or PPP. Else configure them manually with " ip name-server ...".
Then configure "ip domain-lookup" and "ip dns server".
That's it.
thls so much the "ip domain lookup" is no configuring
it's working tks
