How to block a incomplete origin code route in BGP
mohindersingh
Hi Fellow Networkers,
I was trying to block a BGP route with incomplete origin code(?) but got no luck.
i tried route-map but there is no match statement for origin code, i also tried regular expression but still it didn,t work...
Routers are connected in below mentioned fashin.
R1 <---> R2 <---> R3
BGP route is coming from R1 and i am stopping it on R3.
any help really appreciated.
Giuseppe Larosa
Hello Mohinder,
? is a special character in reg exp.
try to use \? to say you want match exactly char '?'
Hope to help
Giuseppe
Hi Guisiar,
Thanks for the reply.
but how to stop the incomplete route..normally regular expression we use with as-path acccess list. but we have to stop a route with incomplete origin code so we can,t use regular expression.
do you know any method to block origin code with regular expression.
Mahi
Hello Mahi,
what you write inside an as path list is actually a regular expression
define an as path list that matches ? at the end of as path
use the as-path access-list inside a route-map
route-map stop-incomplete deny 10
match as-path X
match ip address
route-map stop-incomplete permit 20
empty block to permit all other routes
apply the route-map inbound on R3 on the BGP session with R2 and you should get the result.
Hope to help
Giuseppe
