How to check the licensed throughput on Catalyst 8300 router?
Herman2022
Hi, how to check the throughput on catalyst 8300 router? Is the output of the  following command representing the overall licensed throughput of the router or only represent the throughput of VPN only? Can someone pls advise? thanks in advance! I only see this command is available.
Device# show platform hardware throughput crypto
24 Replies 24
M02@rt37
Hello @Herman2022
Your command is for crypto engine throughput.
Do, #show platform hardware throughput level command in privileged EXEC mode.
Please find here information about throughput:
https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/configure-licenses-throughput-catalyst-8000-platforms.html#Cisco_Concept.dita_349da4fc-6654-4410-a938-5ac474662643
Best regards
Thanks M02@rt37 for your advice. As I mentioned, there is no such command "#show platform hardware throughput level" in privileged exec mode.
router01#sh platform hardware throughput ?
crypto Show crypto throughput
router01#
Ok @Herman2022 ...
I'm gonna check that
Best regards
Router0#show platform hardware qfp active datapath utilization
Share this
MHM
router01#sh platform hardware qfp active datapath utilization
CPP 0: Subdev 0 5 secs 1 min 5 min 60 min
Input: Priority (pps) 0 0 0 0
(bps) 0 0 0 0
Non-Priority (pps) 14357 14967 14334 12304
(bps) 34994816 36878056 32283296 32374576
Total (pps) 14357 14967 14334 12304
Output: Priority (pps) 0 0 0 0
(bps) 0 0 0 0
Non-Priority (pps) 14357 14966 14334 12303
(bps) 34854840 36733384 32142032 32262328
Total (pps) 14357 14966 14334 12303
Processing: Load (pct) 1 1 1 1
Crypto/IO
Crypto: Load (pct) 0 0 0 0
RX: Load (pct) 0 0 0 0
TX: Load (pct) 2 2 2 2
Idle (pct) 97 97 97 97
This router for 60 min have throughput 32-35 mbps so I think it light load router.
MHM
M02@rt37
@Herman2022,
Please provide the output of these two commands:
# show licence summary
# show version
Best regards
Thanks @balaji.bandi @Torbjørn M02@rt37 , below are the output of sh license summary and sh version. We purchased HSEC license, network advantage 1G license. Please advise, thanks. seems something is missing or not configured.
Hello @Herman2022
Regarding your output, the entitlement tag  ESR-P_10M_A maps to a 10Mbps throughput license...
So, your 1G entitlement has not been activated or assigned in your Smart acount, or pulled down and registered by the router...
I let my friend comment also. Thanks again for these outputs.
Best regards
Hi M02@rt37 , I also don't know why the default is 10M and actual traffics volume can reach 200Mbps with any issue. I run the following commands, then both network advantage and DNA advantage are 10M when running the command "sh license summary".
Device(config)# license boot level network-advantage addon dna-advantage
Torbjørn
You should be able to assert which throughput tier your router has by the license name in show license summary.
See the following documentation for tier to throughput mappings: https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/configure-licenses-throughput-catalyst-8000-platforms.html#tier-and-numeric-throughput-mapping
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
balaji.bandi
what is the full model and what License you have ? is this SD-WAN or traditional router deployment.
some guide lines how to check :
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2025/pdf/BRKTRS-2572.pdf
BB
hi @balaji.bandi , the model is 8300, configured as traditional router, not sdwan edge router. The online document is not very clear, don't know the procedure to license the 8000 series routers and how to verify via cli.
Herman2022
Hi @balaji.bandi @Torbjørn M02@rt37 @MHM Cisco World, should configure boot license dna-addon or not?
