OC3 troubleshooting line up protocol down
nawas
Level 4
Level 4
I'm replacing a PA-POS-OC3-SM with PA-POS-1OC3 in a flex Wan module (WS-X6582-2PA) in Cisco 6506 using WS-SUP32P-GE PISA.
I have a hard time bringing the "protocol up. the status I see is line up and protocol down. Debug shows (attached) no comunication with the edge router but when i put the older PA (PA-POS-OC3-SM ) back evertything works fine and older PA has been running for many years without the issue.
I'm replacing older PA is becuase this is going EOL. Any thoughts or suggestions. I had opened a TAC case but the TAC engineer added no value.
PA-POS-OC3-SM   -->>replacing with>>>>  PA-POS-1OC3 with SFP-OC3-IR1
show run int pos4/0/0
interface POS4/0/0
description AGEC.905483
ip address 192.168.200.1.255.255.252
ip access-group internet-filter in
no ip redirects
no ip proxy-arp
no ip mroute-cache
Jan 20 03:00:26.380: %SONET-4-ALARM:  POS4/0/0: SLOS declared
Jan 20 03:00:53.916: %OIR-6-REMCARD: Card removed from slot 4, interfaces disabled
Jan 20 03:00:53.920: %OIR-6-REMCARD: Card removed from slot 4, interfaces disabled
Jan 20 03:00:53.920: %OIR-SP-3-PWRCYCLE: Card in module 4, is being power-cycled off (Module not responding to Keep Alive polling)
Jan 20 03:00:54.908: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Module not responding to Keep Alive polling)
Jan 20 03:01:40.824: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 4/1
Jan 20 03:01:57.500: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 4/0
Jan 20 03:02:02.408: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
Jan 20 03:02:02.408: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
Jan 20 03:02:03.760: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
Jan 20 03:02:04.764: %SONET-4-ALARM:  POS4/0/0: SLOS alarm cleared
Jan 20 03:02:05.084: %SONET-4-ALARM:  POS4/0/0: B1 declared
Jan 20 03:02:05.524: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
Jan 20 03:02:05.524: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
Jan 20 03:02:06.084: %SONET-4-ALARM:  POS4/0/0: B2 declared
Jan 20 03:02:15.088: %SONET-4-ALARM:  POS4/0/0: B1 cleared
Jan 20 03:02:16.096: %SONET-4-ALARM:  POS4/0/0: B2 cleared
cisco-6506 #sh int pos4/0/0
POS4/0/0 is up, line protocol is down
  Hardware is Packet over Sonet
  Description: AGEC.905483
  Internet address is xxxxxxxx/30
  MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
     reliability 169/255, txload 1/255, rxload 1/255
  Encapsulation HDLC, crc 16, loopback not set
  Keepalive set (10 sec)
  Scramble disabled
  Last input never, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3 packets input, 246 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 runts, 2 giants, 0 throttles
              0 parity
     64 input errors, 58 CRC, 0 frame, 0 overrun, 0 ignored, 6 abort
     401 packets output, 20688 bytes, 0 underruns
     0 output errors, 0 applique, 22 interface resets
     22 carrier transitions
cisco-6506# debug serial interface
Serial network interface debugging is on
Jan 20 03:12:24.760: POS4/0/0: HDLC myseq 61, mineseen 0, yourseen 0, line down l
Jan 20 03:12:34.760: POS4/0/0: HDLC myseq 62, mineseen 0, yourseen 0, line down
Jan 20 03:12:44.760: POS4/0/0: HDLC myseq 63, mineseen 0, yourseen 0, line down
Jan 20 03:12:54.760: POS4/0/0: HDLC myseq 64, mineseen 0, yourseen 0, line down
Jan 20 03:13:04.760: POS4/0/0: HDLC myseq 65, mineseen 0, yourseen 0, line down
Jan 20 03:13:14.760: POS4/0/0: HDLC myseq 66, mineseen 0, yourseen 0, line down
Jan 20 03:13:24.760: POS4/0/0: HDLC myseq 67, mineseen 0, yourseen 0, line down
All possible debugging has been turned off
cisco-6506#
Jan 20 03:13:34.760: POS4/0/0: HDLC myseq 68, mineseen 0, yourseen 0, line down
Jan 20 03:14:14.760: POS4/0/0: Reset from PC 0x215C229C
Jan 20 03:14:14.788: POS4/0/0: HDLC myseq 1, mineseen 0, yourseen 0, line up
Jan 20 03:14:24.760: POS4/0/0: Reset from PC 0x215C2258
Jan 20 03:14:24.788: POS4/0/0: HDLC myseq 2, mineseen 0, yourseen 0, line down
Jan 20 03:14:34.760: POS4/0/0: HDLC myseq 3, mineseen 0, yourseen 0, line down
Jan 20 03:14:44.760: POS4/0/0: HDLC myseq 4, mineseen 0, yourseen 0, line down
Jan 20 03:14:54.759: POS4/0/0: HDLC myseq 5, mineseen 0, yourseen 0, line down
Jan 20 03:15:04.759: POS4/0/0: HDLC myseq 6, mineseen 0, yourseen 0, line down
Jan 20 03:15:14.759: POS4/0/0: HDLC myseq 7, mineseen 0, yourseen 0, line down
cisco-65061#show controllers
Interface information:
        Interface EOBC0/0 (idb = 0x26852630)
        Hardware is sb1250 EOBC
        Encap size         = 14         hardware status  = 0x210840
        IDB type           = 18         IDB state        = 4
        Encap type         = 0x1        Span encap size  = 0
        Error threshold    = 5000       Error count      = 0
        Error checking is enabled
Counters:
        rx_ring            = 0x26A69240 rx ring entries        = 512
        rx_head            = 323        rx_tail                = 0
        rx_count           = 3439233347 rx_bytes               = 843855535362
        rx rate (bits/sec) = 184000     rx rate (packets/sec)  = 105
        rx_multicast_pkts  = 38464      rx_bcast_pkts          = 128
        rx_good_pkts       = 4580065854 rx_bad_pkts            = 16278
        rx_buf_unavail     = 0          rx_fcs_err_pkts        = 16278
        rx_runt_pkts       = 9582       rx_oversize_pkts       = 0
        rx_pkts_len_err    = 0          rx_pkts_dropped        = 0
        rx_bad_pkts_dropped= 13207      rx_bad_len_pkts_dropped= 0
        rx input drops     = 1715
        rxr eobc shadow    = 0x308B1218
        tx ring            = 0x26A69240 tx ring entries        = 0x200
        tx_head            = 149        tx_tail                = 149
        tx_good_pkts       = 2954522773 tx_bad_pkts            = 0
        tx_bytes           = 295475148735
        tx rate (bits/sec) = 71000      tx rate (packets/sec)  = 83
        tx_late_coll       = 0          tx_excessive_coll      = 0
        tx_crc_err         = 0          tx_aborted_pkts        = 0
        tx total drops     = 0
POS4/0/0
SECTION
  LOF = 0          LOS    = 0                            BIP(B1) = 1015
LINE
  AIS = 0          RDI    = 0          FEBE = 105        BIP(B2) = 208
PATH
  AIS = 0          RDI    = 0          FEBE = 68         BIP(B3) = 93
  PLM = 1          UNEQ   = 0          TIM  = 0          TIU     = 0
  LOP = 0          NEWPTR = 1102       PSE  = 1600       NSE     = 1
Active Defects: PPLM
Active Alarms:  None
Alarm reporting enabled for: SF SLOS SLOF B1-TCA B2-TCA PLOP B3-TCA
Framing: SONET
APS
  COAPS = 1          PSBF = 0
  State: PSBF_state = False
  Rx(K1/K2): 00/00  Tx(K1/K2): 00/00
  S1S0 = 00, C2 = 16
  Remote aps status (none); Reflected local aps status (none)
CLOCK RECOVERY
  RDOOL = 0
  State: RDOOL_state = False
PATH TRACE BUFFER: STABLE
  Remote hostname : dtrmi31ck
  Remote interface: POS5/9
  Remote IP addr  : 12.124.15.37
  Remote Rx(K1/K2): F1/FF  Tx(K1/K2): 08/00
BER thresholds:  SF = 10e-3  SD = 10e-6
TCA thresholds:  B1 = 10e-6  B2 = 10e-6  B3 = 10e-6
  Clock source:  line
vmiller
Level 7
Level 7
Correct optics in the card & handoff to the carrier ? bad fiber someplace ?
these input/crc errors were only seen when i inserted the card and no errors after that, i have used a brand new fiber all the way to CPE. the disctance was only 8 meter, same goes to optic, tried three different optics but no help. I suspect that there is a compatibility issue
