How to define a part of subnet in ACL?
SludnevTN_2
Is it possible to define only this range of hosts: 192.168.80.200-254 /24 in standard ACL without entering each host per line?
Thank you.
ip access-list standard PAT
permit 192.168.80.200
permit 192.168.80.201
permit 192.168.80.254
Any other ways?
15 Replies 15
paolo bevilacqua
No. You're limited to specify a wildcard mask, to the extent your range is falling on bit boundaries. e.g 0.0.0.1 for x.x.x.200-201
Edison Ortiz
You can accomplish the task with 3 lines:
permit 192.168.80.200 7.255.255.255
permit 192.168.80.208 15.255.255.255
permit 192.168.80.224 31.255.255.255
HTH,
___
Edison.
Edison
Shouldn't that be -
permit 192.168.80.200 .0.0.0.7
permit 192.168.80.208 0.0.0.15
permit 192.168.80.224 0.0.0.31
Jon
Jon,
Yes, posting while on the phone isn't something I recommend :)
__
Edison.
You're taking it the wrong way Edison (and I do not mean the wildcard mask).
You've just been talking while posting, not viceversa.
With a little practice, you will learn how to screw up both things at the same time. One only, is for beginners.
Paolo,
I actually did.
While posting, I was asked a question and I was dumbfounded :(
Good job, I'm proud of you. We're not Engineers for nothing.
Thank you.
How do you do this so quickly? I understand a logic, but... did you use some tools? IP calc?
PLEASE DO NOT POST THE SAME QUESTION ON TWO DIFFERENT THREADS.
Please do not post in uppercase neither :)
Victor,
Please, that's uncalled for..
Whats un-called for. Asking him not to post the same question on 2 threads?
Or using CAPS?
The CAPS is just an attention-getter. Were I yelling at him, I would have used "!" OK!!!!!!??????? :-D
OK
Tim,
It comes with experience.
I haven't used any IP Calculator for a LONG time.
__
Edison.
