How to find this particular patch version is vulnerable?
Mohammed.MY
I have used Cisco software to find vulnerabilities and patches but I don't understand one thing how to particular model is vulnerable. if these have specific versions how to find out if this particular model is vulnerable.
For example
WS-C2960S-48FPS-L
WS-C2960S-48LPD-L
N9K-C93180YC-EX
ASR-1001-X Routers
@Mohammed.MY hi use below tool for the checkings.
Cisco Software Checker
Good luck
KB
balaji.bandi
Most cases the vulnerability based on the Code running it, so please check below URL :
https://sec.cloudapps.cisco.com/security/center/publicationListing.x#~FilterByProduct
Note : the More concern need to when the device is externally exposed to Internet (if the devices are behind firewall you are some what ok) - but again there is possibility internal threat.  if you are restricted environment that should ok for somelevel.
BB
