How to get serial number with command (show diag not working)
news2010a
Level 3
Level 3
Folks, I need to get serial number from remote 6509.
I tried 'show diag' but no output returned.
This is IOS version 12.2(18).
3 Accepted Solutions
Collin Clark
Try show inventory
Hope that helps
otzispadmin
Does sh ver work? The processor board id is the s/n.
foxbatreco
Level 3
Level 3
Sh ver command should work with 6509 to view the serial no.
U can find it appended with Process Board ID.
Pls rate/mark if this helps!!!
7 Replies 7
Collin Clark
Try show inventory
Hope that helps
otzispadmin
foxbatreco
Level 3
Level 3
True. I did not realize that "processor board" is the same than "SN"!
Thanks all!!!
"processor board" is NOT  the same as "SN"
hsitar007
'Show module' would be the appropriate command on a 6509. It would even provide the card serial number along with the chassis serial number.
Ratish
h.parsons
Level 3
Level 3
I use "show idprom backplane" if you are looking for the chassis SN. If not the there are other options after "show idprom ________"
