How to Learn switch ports IP?
ersin erol
Hi everybody,
ı want to ask that; On  the switch ı know switch's mac address table.For exaple gi0/11 mac adddres:xxxx.xxxx (show mac-address table).And than ı want to learn this mac adress's IP ?is there command for this?
#show mac-address table
Get the mac-adress of devices from here then go to layer 3 device # show ip arp | inc mac-address. Sometimes you might need to ping that ip from layer 3 switch to get the arp.
Ajay
7 Replies 7
eric.lovelace
Do a sh arp | inc the mac address and it will tell you what ip is associated with that mac. If the neighbor is another Cisco device and you have cdp enabled do a sh cdp neighbors.
Unfourtanately 1.step:Login the Switch and than show inter gi0/1 status and than ı have seen the mac adress.Then I wrote show arp | inc mac adress. But I Haven't seen where is my wrong?
sh interface g0/1 status should not show you the mac address for that interface.
If you are looking for the ip address of an interface do a sh int g0/1 or a sh ip int br g0/1
Show IP arp will get you arp on Layer 3 device could be layer3 switch /router /firewall. So make sure where is your gateway interface vlan / interface with IP address.
Ajay
I see,ı understood that but mine question is different ı wanted to learn that..After #show mac-address table command.There are  mac-adresses.After I saw this command:Can ı write a command,from the table any mac adress's to learn it's ip?
Ajay
chris.macleod
If the ip / MAC mapping is not in the arp table I often look for the MAC address in our DHCP servers lease list.
