How to monitor traffic port on WAN Connection
cisco
Dear All,
Somebody can tell me what is the command on my cisco router to monitor the traffic port on WAN connection?
mean that I want to see what is the ports number that go through my WAN connection.
Best Regards;
Boly
shivlu jain
Level 5
Level 5
sh ip traffic but instead of this you can use the monitor session command on switch
monitor session 1 source port
monitor session1 destination port
regards
shivlu
Amit Singh
Boly,
You can enable netflow on cisco routers for the same.
You can also use 3rd party freeware to see the sample output.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e387d.html
http://www.softsea.com/review/NetFlow-Configurator.html
HTH,
-amit singh
You can tap the wan interfaces using fluke network analyser probes.
This might be a costly solution as different wan interfaes would require different type of probes
I agree with amit that netflow would be the best tool to get the details you want
Narayan
