How to Route All Traffic from Multiple VLANs through a Specific Public
smithrufy
I'm managing a pfSense setup with multiple public IP addresses ranging from 198.51.100.241 to 198.51.100.246. My ISP has also routed a subnet (203.0.113.1/24) through one of these public IPs (198.51.100.245).
Configuration Details:
  • I have set up an interface (VLAN) for 203.0.113.1/24.
  • Outbound NAT is configured to use 203.0.113.1/24 through the public IP 198.51.100.245.
Goal:
  • I need to route all traffic from my other apkbeb VLANs/networks (specifically, the 192.168.0.0/16 network) that goes to 203.0.113.1/24 through another public IP (198.51.100.241 or 198.51.100.245) instead of directly.
Issues:
  • I attempted to create static routes with destination 203.0.113.1/24 through gateways 198.51.100.241 and 198.51.100.245, but these configurations did not work (traffic went directly).
  • I do not have 1:1 NAT or Port Forwarding (the 203.0.113.1/24 is just another VLAN)
Is there a method within pfSense to force all traffic from 192.168.0.0/16 to route through the public IP 198.51.100.241 without using direct 1:1 NAT or Port Forwarding? Are there specific settings or rules in pfSense that can accomplish this redirection of traffic?
balaji.bandi
First you need to ask this in pfSense forum
my views for your question -
you can directly use pool of IP 203.0.113.1/24 ( you do not need to NAT again using another Public IP)
they are fully routable IP so what you need to do is
source - 192.168.0.0/16 NAT with pool of IP 203.0.113.1/24
check some video - may be helpfull :
https://www.youtube.com/watch?v=HkJ8fTT9yqk
BB
