- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-13-2017 09:08 PM - edited 03-05-2019 09:08 AM
Alright I cant belive I cant get this but I am trying to upgrade my IOS on my router 3900 series, 3945 chassi.
This routers IOS has not been updated since 2011, I get an error when I try to boot from the new IOS I am trying to put on it, the error is incorect platfor then it boots on the old IOS i am trying to update. the IOS it currently has is..........
C3900e-universalk9-mz.SPA.151-3.T1.bin.................. here is the IOS softwear and version that it currently has...... Cisco IOS software, C3900e software (C3900e-UNIVERSALK9-M), Version SOFTWARE 15.1 (3) T1, RELEASE SOFTWARE (fc2)
this is the IOS we are trying to put in the router is c3900-universalk9.SPA.155-3.m6.bin
now i thought it was the format of the usb drive it is formated to FAT32 the router reads what is on there but wont boot from it again it says error incorrect platfor. thank you for your time any help would be amazing
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 10:54 PM - edited 09-13-2017 10:55 PM
Thanks for the output.
The appliance is a 3945, however, the IOS found in the directory output shows the file meant for a 3945e.
IOS for the 3945 can be found HERE.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 09:55 PM
1. sh version;
2. sh inventory; and
3. dir
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 10:11 PM
show ver:
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Mar-11 11:02 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T2, RELEASE SOFTWARE (fc1)
R1 uptime is 2 days, 3 hours, 16 minutes
System returned to ROM by reload at 01:42:29 UTC Tue Sep 12 2017
System restarted at 01:44:18 UTC Tue Sep 12 2017
System image file is "flash0:c3900e-universalk9-mz.SPA.151-3.T1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9 with 1723392K/308224K bytes of memory.
Processor board ID FTX********
7 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice E & M interfaces
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C3900-SPE250/K9 FOC********
Technology Package License Information for Module:'c3900e'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data datak9 Permanent datak9
show inventory:
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V02, SN: FTX********
NAME: "Cisco Services Performance Engine 250 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 250 for Cisco 3900 ISR"
PID: C3900-SPE250/K9 , VID: V02 , SN: FOC********
NAME: "High Speed WAN Interface Card - 1 Port Gigabit Ethernet on Slot 0 SubSlot 0", DESCR: "High Speed WAN Interface Card - 1 Port Gigabit Ethernet"
PID: HWIC-1GE-SFP , VID: V01 , SN: FOC********
NAME: "1000BASE-LX SFP", DESCR: "1000BASE-LX SFP"
PID: FTLF1318P2BCL-C2 , VID: A , SN: FN********
NAME: "3rd generation two port EM voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation two port EM voice interface daughtercard"
PID: VIC3-2E/M , VID: V02 , SN: FOC********
NAME: "SM-ES2-24: EtherSwitch SM L2 + 23 10/100 + 1 10/100/1000 on Slot 1", DESCR: "SM-ES2-24: EtherSwitch SM L2 + 23 10/100 + 1 10/100/1000"
PID: SM-ES2-24 , VID: V01 , SN: FOC********
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V03, SN: SN********
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
dir:
Directory of flash0:/
1 -rw- 62426748 Jul 15 2011 15:08:04 +00:00 c3900e-universalk9-mz.SPA.151-3.T1.bin
2 -rw- 2903 Jul 15 2011 15:18:28 +00:00 cpconfig-39xx.cfg
3 -rw- 2941440 Jul 15 2011 15:18:44 +00:00 cpexpress.tar
4 -rw- 1038 Jul 15 2011 15:18:52 +00:00 home.shtml
5 -rw- 115712 Jul 15 2011 15:19:00 +00:00 home.tar
6 -rw- 1697952 Jul 15 2011 15:19:18 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7 -rw- 415956 Jul 15 2011 15:19:30 +00:00 sslclient-win-1.1.4.176.pkg
8 -rw- 660 Sep 12 2017 01:45:06 +00:00 vlan.dat
9 -rw- 18937 Oct 13 2016 07:39:14 +00:00 backup_2016-10-13_wjh.txt
10 -rw- 21703 Aug 10 2017 13:40:20 +00:00 beforeQoS
1024655360 bytes total (956891136 bytes free)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 11:02 PM
Thank you for your help but im sorry for my stupidity can you please explain what the importance about the e is please???????
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 11:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 11:08 PM
ok thank you so much for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2017 11:09 PM
