IOS XR AS-PAth Prepending route-policy
Sorry I put the wront policy in my question; here is my corrected version:
we are multihomed with two diefferent ISPs (i.e. ISP1 with AS 1100, ISP2 with AS 2200); our own AS is i.e. 5000. We are running  IOS XR 6.6.3 using the following configuration
router bgp 5000
address-family ipv4 unicast
neighbor 10.100.83.1
remote-as 1100
ebgp-multihop 2
update-source Loopback0
route-policy rp-filter-out out
neighbor 10.200.80.1
remote-as 2200
ebgp-multihop 2
rout-policy filter:
  # bgp out policy
  if as-path in (ios-regex '^$') then
    pass
  endif
end-policy
We want to add an AS PATH prepend to our peering with ISP1(AS 1100); is the following RP correct or not ?
route-policy rp-asp-prepend
# prepend 5000 5000
prepend as-path 5000 2
end-policy
# bgp out policy
if as-path is-local and as-path neighbor-is '1100' then
apply rp-asp-prepend
pass
elseif as-path is-local then
  pass
else
  drop
end-policy
Harold Ritter
Hi @MANFRED LIEBCHEN ,
Your RP will not accomplish what you want, as the following condition applies to the as-path in the route, rather than the peer-as.
The following RP should work for you. Please test it in you lab first.
route-policy rp-filter-out($peeras)
var globalVar1 $peeras
if globalVar1 eq 1100 and as-path is-local then
else
pass
endif
endif
end-policy
router bgp 5000
route-policy rp-filter-out(1100) out
route-policy rp-filter-out(2200) out
With out pass the route will drop not advertise even if it not modify.
by the way this guide is wonderful for IOS XR it have many many LAB.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/5eU6DfQV/LTRARC-2002-LG.pdf
  Sticking with Cisco configuration guide example, you dont need:
The following example shows how to prepend the autonomous system number 666.1 to the AS path three times:
RP/0/0/CPU0:router(config-rpl)# prepend as-path 666.1 3
The following example shows how to prepend the autonomous system number 666.0 to the AS path one time:
RP/0/0/CPU0:router(config-rpl)# prepend as-path 666.0 1
Harold Ritter
else
pass
endif
endif
end-policy
router bgp 5000
Thanks very much, your hint works fine
