IP Mobility with 1921 router
nfetlyaev
Does 1921 router support IP Mobility?
If yes, what IOS and License should be used?
1921 router - check the EOL/ EOS - again you can cehck the feature navigator for the features.
BB
7 Replies 7
balaji.bandi
Thanks for the link! Unfortunately it might be a little bit outdated. Based on the link, the 1921 router is not in the list of the Cisco platforms supporting IP Mobility. At the same time, the 1921 router's datasheet states that the IP Mobility is supported.
Cisco 1921 Series Integrated Services Routers Data Sheet - Cisco
BB
Thanks! I've found it supports Mobile IP.
Based on Cisco Feature Navigator the current IOS version (c1900-universalk9-mz.SPA.154-3.M3.bin) of the 1921 router should support Mobile IP, however, when I enter the command "router mobile" I get this: "Protocol not in this image".
Any suggestion?
The current license is IP Base:
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
data None None None
NtwkEss None None None
I've tried to downgrade (c1900-universalk9-mz.SPA.150-1.M4) and upgrade (c1900-universalk9-mz.SPA.157-3.M8) the IOS image of the router but still failed to run Mobile IP.
It seems the router "CISCO1921/K9" has the right license and IOS image but doesn't like Mobile IP for some reason.
BB, Is any other potential reason of Mobile IP not supported by the 1921 router? Based on Cisco Feature Navigator, it should support if its IOS is Version 15.4(1)T2. The bellow is output of "sh ver" command:
Router#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(1)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 30-Jul-14 08:48 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 4 days, 20 hours, 30 minutes
System returned to ROM by reload at 17:52:29 EDT Fri Sep 23 2022
System restarted at 17:54:06 EDT Fri Sep 23 2022
System image file is "flash:c1900-universalk9-mz.SPA.154-1.T2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FJC2004E0F0
10 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO1921/K9 FJC2004E0F0
Technology Package License Information for Module:'c1900'
data None None None
