ip nat inside
gio.bitsadze
ip nat inside source static tcp 192.168.200.45 5000 interface GigabitEthernet0/0/0 5000
%Port 5000 is being used by system
any guesses?
17 Replies 17
Jaderson Pessoa
Well,
this port is already in use by your router.. you can use the show tcp to check who is responsible for unavailable port. But you can change the port if possible.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Already, port isn't in use ((
Georg Pauwen
 all
try and shut all active interfaces, then clear the NAT translations (clear ip nat translation *), then add the static entry. Don'y forget to 'no shut' your interfaces...
Ok, Interesting, I will try that tomorrow
not working ((
you get the same message, even with just that one static NAT entry ?
What router is this on ? Can you issue the exec command:
sh ip nat portblock dynamic global
I think then a good option to share running configuration with us
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Using 2964 out of 33554432 bytes
! Last configuration change at 15:51:01 UTC Tue Oct 22 2019 by cisco
version 15.4
no platform punt-keepalive disable-kernel-core
hostname xxxxxxxx
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password xxxxx
no aaa new-model
ip domain name xxxx
ip host xxxx 192.168.200.46
ip host xxxx192.168.200.77
ip name-server 8.8.8.8
ip name-server 192.168.200.77
ip dhcp excluded-address 192.168.200.1 192.168.200.100
ip dhcp excluded-address 192.168.200.200
ip dhcp pool xxxx
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
dns-server 192.168.200.77 8.8.8.8 8.8.4.4
subscriber templating
license udi pid ISR4331/K9 sn FDO191117MT
license accept end user agreement
license boot level securityk9
username xxxx privilege 15 password 0 xxxx
redundancy
mode none
ip tftp source-interface GigabitEthernet0
ip ssh version 2
ip address 188.169.xxxx.xxxx 255.255.255.252
ip nat outside
ip access-group outside-in in
negotiation auto
interface GigabitEthernet0/0/1
ip address 192.168.200.1 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip nat inside source static tcp 192.168.200.46 80 interface GigabitEthernet0/0/0 80
ip nat inside source static tcp 192.168.200.52 22 interface GigabitEthernet0/0/0 5222
ip nat inside source static tcp 192.168.200.11 902 interface GigabitEthernet0/0/0 902
ip nat inside source static tcp 192.168.200.11 443 interface GigabitEthernet0/0/0 443
ip nat inside source static udp 192.168.200.30 14872 interface GigabitEthernet0/0/0 14872
ip nat inside source static tcp 192.168.200.45 8081 interface GigabitEthernet0/0/0 8081
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 188.169.xxxx.xxxx
ip access-list extended outside-in
permit tcp host 193.239.217.81 any eq 443
permit tcp host 193.239.217.81 any eq 902
permit tcp host 213.110.132.201 any eq 443
permit tcp host 213.110.132.201 any eq 902
deny tcp any any eq 443
deny tcp any any eq 902
permit ip any any
access-list 1 permit 192.168.200.0 0.0.0.255
control-plane
line con 0
logging synchronous
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
password cisco
login local
transport input ssh
end
what is the output of:
show ip nat portblock pat global
When you entered the static NAT command, was that your first line, that is, did you enter:
before
Also, if this is an ISR4K router (is it ?), version 15.4 contains a bug which causes this issue. Upgrade to the recommended release Fuji-16.9.4 MD if possible...
outer#show ip nat portblock dynamic global
tcp: 4096 -5119 545 -617
udp: 4501 -5524 512 -584
Jaderson Pessoa
Hello guy,
Just test it and put here the result:
ip nat inside source static tcp 192.168.200.45 5001 interface GigabitEthernet0/0/0 5001
Jaderson Pessoa
router(config)#$00.45 5001 interface GigabitEthernet0/0/0 5001
%Port 5001 is being used by system
router(config)#$00.45 4999 interface GigabitEthernet0/0/0 4999
router#show ip nat portblock dynamic global
tcp:
4096 -5119 545 -617
udp:
4501 -5524 512 -584
