ip nat pool with prefix-length to translate to a /32 address
Hi !
i have a nat statement :
ip nat inside source list VLAN108_NAT interface GigabitEthernet0/1 overload
and i want to change it from interface dependent to a "floating nat" .
can i use this ?
ip nat pool VLAN_108_NAT_POOL 212.11.55.55 212.11.55.55 prefix-length 23
ip nat inside source list VLAN108_NAT pool VLAN_108_NAT_POOL overload
- what does the prefix-length stands for ? is it suppose to be the 212.11.55.55 real subnet , or is it the private addresses range length ?
- is it better to do it with a loopback intercae instead of the prefix-length ?
Thanks !
cadet alain
this is the netmask of the subnet where the pool resides.
Regards.
Alain
