IP route configuration packet tracer routerr
Hello everyone ,
I have a problem on my packet tracer, in fact I would like to add 2 IP route on my router but I have "%invalid input detected" I don't now why..
If you have a solution enjoy
Gautier
you do not need any static routes at all. You have one router and two directly connected networks, so the routing is automatic.
Your problem is that both PCs did not have their default gateways configured. After adding these to each PC, end to end commnication worked.
Attached the revised file (saved in version 8).
14 Replies 14
balaji.bandi
The syntax is here :
#ip route x.x.x.x 255.255.255.0 y.y.y.y  ( x.x.x.x is the source network, y.y.y.y. destination IP where you want to route that subnet)
here is good reference to understand :
https://www.cisco.com/c/en/us/support/docs/dial-access/floating-static-route/118263-technote-nexthop-00.html
BB
Hello B.B
It's possible to have all ip route for my diagram ?
Now I have this one :
ip route 192.168.1.0 255.255.255.0 192.168.2.0
and the same ip route 192.168.2.0 255.255.255.0 192.168.1.0
Thx you
post the zipped Packet Tracer project (.pkt) file...
Hello, just change the name exemple.tar with exemple.pkt
When I would like to add Ip route on my switch it s impossible ..
Thank you
on what device .  ISR 4331
Towards Switch 1
ip route 192.168.1.0 255.255.255.0 192.168.1.1
Towards Switch 2
ip route 192.168.2.0 255.255.255.0 192.168.2.1
On switch 1
ip route 0.0.0.0 0 0,0,.0,0  192.168.1.2
On switch 2
ip route 0.0.0.0 0 0,0,.0,0  192.168.2.2
BB
looking at the screenshot, are you actually in config mode ?
Router#conf t
Router(config)#ip route ....
Hello Yes I am with enable and conf terminal
Thx u
post the project file...
Yes but I can't upload file type .pkt this the reason why I will send my drive with pkt  https://drive.google.com/file/d/1oJoVW9riNOXaUiqdbFZazb9kBa9t5Bi8/view?usp=sharing
Thank you,
Gautier
Hello thank you very much,
I will check you .pkt but I can't open it because I have packet tracer 7 ! Itry to install 8 version
just add the default gateways to the PCs, 192.168.1.2 to the left PC, and 192.168.2.2 to the right PC. Also, delete the two static routes in the router config.
okay thank you !
If I have a big infrastructure, how to choose default gateway for server A in my attachement a.png?
