05-28-2024 06:34 AM
Hello guys, below is my topology,
I have added internet fw and introduced ISP on site B.
Before site B resources/ servers would go via mpls to site a to access internet.
I introduced the above to make each site use its own isp respectively.
I ran to challenges, site b resources were not able to get to their isp/internet, until i introduced " ip route 0.0.0.0/0 sitebinternetfw interface. --> which works but causes some issues.
is there a way, to manipulate just internet traffic for site b resources without introducing static entries? and not affecting site a and b from communicating with each other?
Solved! Go to Solution.
06-06-2024 04:59 AM
some prefix is learn via OSPF other is direct connect to R1 and hence same as previous
you need
redistribute connect into bgp to make 10.185.40/80.0 to advertise
MHM
06-06-2024 05:33 AM
since R1 has ospf which has connected redistributed to it, then ospf redistributed to bgp? this is not enough?
i have to redistibuted the connected again on bgp?
06-06-2024 05:53 AM
since R1 has ospf which has connected redistributed to it, then ospf redistributed to bgp? this is not enough? Yes
You need to redistribute connected into bgp
MHM
06-06-2024 05:19 AM
what if i remove the static configuration domain from bgp border routers, r3 in this case. make r3 have ospf with r5.
see now r3 does not have any static route on its rib/fib.. how do i proceed now letting it know static route on r6?
06-06-2024 05:51 AM
in R5 do
redistribute static into ospf
in R3 do
redistribute ospf into bgp ONLY no need any more need redistribute static into bgp in R3 since now R3 know the prefix via ospf
MHM
06-06-2024 06:22 AM
this is done, but r1 does not learn any bgp routes from r3.
06-06-2024 06:28 AM
can I see
show ip bgp
in both R1 and R3
MHM
06-06-2024 06:34 AM
06-06-2024 06:39 AM - edited 06-06-2024 06:39 AM
I will focus on 10.185.45.0/24 prefix here OK
it must advertise by R3 to R1
NOW
show ip bgp neighbor <<- in R3
I need to see route-map you use in bgp not only prefix <- in R3
MHM
06-06-2024 06:47 AM
R3#sh ip bgp neighbor
BGP neighbor is 102.69.239.201, remote AS 64512, external link
BGP version 4, remote router ID 172.16.20.1
BGP state = Established, up for 00:00:23
Last read 00:00:23, last write 00:00:23, hold time is 180, keepalive interval is 60 seconds
Neighbor capabilities:
Route refresh: advertised and received(new)
New ASN Capability: advertised and received
Address family IPv4 Unicast: advertised and received
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 0 0
Keepalives: 1 1
Route Refresh: 0 0
Total: 2 2
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
BGP table version 1, neighbor version 0/0
Output queue size : 0
Index 1, Offset 0, Mask 0x2
1 update-group member
Inbound soft reconfiguration allowed
Outbound path policy configured
Route map for outgoing advertisements is ROUTES-OUT
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 0 0
Prefixes Total: 0 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 0, min 0
Address tracking is enabled, the RIB does have a route to 102.69.239.201
Connections established 1; dropped 0
Last reset never
Transport(tcp) path-mtu-discovery is enabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: 102.69.239.202, Local port: 27347
Foreign host: 102.69.239.201, Foreign port: 179
Connection tableid (VRF): 0
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x23960):
Timer Starts Wakeups Next
Retrans 3 0 0x0
TimeWait 0 0 0x0
AckHold 1 0 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 1 0 0xADE8C
DeadWait 0 0 0x0
Linger 0 0 0x0
ProcessQ 0 0 0x0
iss: 320437820 snduna: 320437893 sndnxt: 320437893 sndwnd: 16312
irs: 1213698146 rcvnxt: 1213698219 rcvwnd: 16312 delrcvwnd: 72
SRTT: 105 ms, RTTO: 1593 ms, RTV: 1488 ms, KRTT: 0 ms
minRTT: 76 ms, maxRTT: 348 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 4 (out of order: 0), with data: 2, total data bytes: 72
Sent: 4 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 2, total data bytes: 72
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
06-06-2024 06:49 AM
Updates: 0 0 <<- no update send receive
can I see the route-map you use
not only it prefixs list
MHM
06-07-2024 01:48 AM
seems i dont have a route map configured.
let me configure it.
apologies.
06-07-2024 01:50 AM
Dont worry
we here support each other
take your time
ask more before apply commands in real network
goodluck
MHM
06-07-2024 01:54 AM
after adding route-map, it worked.
but stil r1 does not know the 172.16.57.0/24 network. i left it out of r3 prefix-list, since i have a real production evn where lots of clients with /32 terminate to a ipsec vpn.
how do i make r1 learn 172.16.57.0/24 network via r3 via bgp ?
06-07-2024 01:56 AM
did you include it in prefix list you use in route-map ?
MHM
