Showing results forĀ
Search instead forĀ
Did you mean:Ā
IP SLA Monitor on Cisco 2911
zaoclaude
Dear all,
I have a cisco 2911 router that is located in my head office LAN and I use this router to connect to my branch networks. I want to configure IP SLA Monitor on this router to track my WAN Links but it does not support the command IP SLA Monitor. My IOS VERSION is  c2900-universalk9-mz.SPA.151-2.T1.bin. Please help tell me how I can configure IP SLA on my router.
Any assistance will be highly appreciated.
6 Replies 6
Pulkit Nagpal
Hello Claude,
Have you tried using command reference for 15.1 M&T:
http://www.cisco.com/en/US/products/ps10592/prod_command_reference_list.html
Please have a look at it and see if it helps.
If your query has been answered, please mark this quesy as answered so that it can help others.
Pulkit
You probably have the IP Base license activated. for IP SLA you need Data license
No need to change IOS ,but What you need is an activation key from Cisco which will enable the new features.
I also faced some problem some time back .with default base IOS IP SLA will not work
Haris P
Pulkit Nagpal
Hello Claude,
If you think your query has been addressed, can you please mark this post as answered? This way others can benefit from this discussion as well.
Pulkit
emmanuel-MD
Hi Haris,
You are right, IP Base License does not support IP SLA according to the section "Universal IOS Packaging Overview" on the following URL:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html
But what I want to know is will IP SLA become available if I purchase just security license without data license?
Nilo Noguera
Level 5
Level 5
The Data Technology Package License part number SL-29-DATA-K9 was changed to the AppX Technology Package License that includes DATA and WAAS features with part number SL-29-APP-K9.
SL-29-APP-K9 (AppX License for Cisco 2900 Series) - USD 1,000.00
Please check the Change in Product Part Number Announcement for the Cisco 2900 Series Integrated Services Routers Data Technology Package Licenses link below for your reference(s):
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-730946.html
"niLz" Nilo Noguera Jr. | Specialist, Virtual Engineering - Partner Helpline Organization together we are the human network
Hi, with the new APP technology package, does the IP SLA feature require de SL-29-APP-K9 or it's now included in IP Base?
Thank you.
