IP SLA not able to Generate syslog messages
mrathi_ablp
I have set up IP SLA on a device and probing 10 different devices from it.
Everything is working except that I am not able to generate syslog messages.
This is my configration :
ip sla 1
udp-echo 10.83.xx.xx 2000
threshold 25
  frequency 10
history lives-kept 2
history filter failures
ip sla reaction-configuration 1 react rtt threshold-value 25 22 threshold-type immediate action-type trapOnly
I have these two commandsd in place as well:
ip sla logging traps
snmp-server enable traps ipsla
Any idea what i am doing wrong or what am I missing?
czaja0000
1. Try this command:
snmp-server enable traps rtr
Pls let me know.
2. You can also configure EEM (Embedded Event Manager) script to monitor the IP SLA.
Link to the instruction: Generating syslog alarms for RTR/IP SLA probes
________________
Best regards,
MB
________________ Best regards, MB
I tried the command but it didnot work.
Intrestingly, i tried the Reaction-configuration to react on Timeout and I could see the syslog messages.
Is the RTT in my command latest RTT or average RTT?
