ipv6 issue
S891
Level 2
Level 2
I am having an issue with ipv6 communication over SVI interfaces. This is on Cisco Catalyst 6824 swiches.  The SVI has dual stack configuration. I can access on ipv4 but some reason ipv6 is broken. I can see the mac address but ping ipv6 is not responding.
The mac address is visible across the trunk but layer-3 ipv6 reachability is not there. Not sure if there is something missing...
sw-1#
interface Vlan699
vrf forwarding WXZ
ip address 10.66.39.2 255.255.255.240
no ip redirects
no ip proxy-arp
standby version 2
standby 1 ip 10.66.39.1
standby 1 timers msec 200 msec 750
standby 1 priority 110
standby 1 preempt delay minimum 60
standby 1 mac-address 0080.7fed.0699
standby 2 ipv6 autoconfig
standby 2 priority 110
standby 2 preempt delay minimum 60
standby 2 mac-address 0086.7fed.0699
ipv6 address 2DDD:AB1:0:101::1/64
ipv6 enable
no ipv6 redirects
end
sw-2#
interface Vlan699
vrf forwarding WXZ
ip address 10.66.39.3 255.255.255.240
no ip redirects
no ip proxy-arp
standby version 2
ipv6 address 2DDD:AB1:0:101::2/64
ipv6 enable
no ipv6 redirects
end
sw-1#ping vrf WXZ 10.66.39.3
Sending 5, 100-byte ICMP Echos to 10.66.39.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
sw-1#ping vrf WXZ ipv6 2DDD:AB1:0:101::2
Sending 5, 100-byte ICMP Echos to 2DDD:AB1:0:101::2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
balaji.bandi
what is the version of code and can you post both the device
show standby
BB
Deepak Kumar
Is IPV6 routing enabled? What is the IOS version?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
