Is per-packet load sharing only by CEF? Is this something that can blow your mind?
sydflyer2011
Hi guys,
Just a bit confusion here. I know from Cisco documentation, per-packet load balancing is only enabled via CEF. But while I am doing labs in GNS3, I think I have enabled per-packet load sharing and at the same time disabled CEF, which means fast switching is ON! Oh well, my screenshot could tell:
Fast swiching is ON right?  And Per-packet load-sharing is on, Right?  Tell me if I am wrong. Please.
This is the config:
Cheers,
Alex
23 Replies 23
Hi Alex,
As the fa0/0 and fa0/1 have CEF deactivated, the traffic will be fast-switched, assuming the egress interface at the left side is fast-switched. With fast switching, per-destination load balancing will take place.
Best regards,
Peter
Hi Peter,
I found new problem: the interface that connects to the PC is a switch port. That means that port is not configurable in terms of switching method. Also means that we need to scrape the previous discussions (that's what I doubt).
Alex
sydflyer2011
Thanks all, it is all clear as my input interface is still on CEF mode, overally the two egress interfaces are still load-balanced by CEF.
Best Regards,
Alex
sydflyer2011
Hi guys, this discussion may not be finished yet because the port connecting to the PC is a switchport, so I reckon the switching method on fa0/0 and fa0/1 are just purely fast switching. Any more thoughts are welcome!
Alex
Hi Alex,
Well, if the input port is a switchport then surely, there must be a SVI interface configured in your router - and that one is running with CEF active by default.
Best regards,
Peter
Thanks Peter. I indeed has a vlan 1 interface configured (which was by default enabled for CEF). And it looks like it became per-destination load sharing as all traffic from the PC to the other end only went out of fa0/0  after I disabled CEF on that vlan 1 interface --- which is correct according to that switching method rule table.
Just a bit confusing to see the output of show ip cef x.x.x.x still tells me that per-packet load-sharing is ON (actullay not).
Alex
Hi Alex,
It's good to know that your experiments start aligning with the documentation
Well, consider the fact that in the show ip cef x.x.x.x command, you are asking about a particular destination but you are not saying through which interface did the packets to this destination came into your router - and for CEF, the ingress interface is important. So the output indeed tells you what would happen to the packets if they came via a CEF-enabled interface. After all, if you know that the ingress interface is not CEF-enabled then it doesn't make sense to ask CEF what it would do with those packets
Best regards,
Peter
Thanks again, Peter.
paolo bevilacqua
Have you ever noticed that when working with Cisco CLI, is not needed to take screenshot ? Just copy and paste text.
