ISDN configuration confused
d_unafraid
Hi All
I am having some difficult time trying to setup my ISDN line for internet access. I have two ISDN line going to a single router, my configuration is as of below, what am i missing?
I am understood from the ISP that SPID configuration is not required as well as the name and password. I read up from some book that mention a command line that say "dialer-map ip", what is this? and if this is necessary to get the configuration working?
interface BRI0
ip address negotiated
encapsulation ppp
dialer idle-timeout 30
dialer string 62714212
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-net3
ppp multilink
interface BRI1
encapsulation ppp
dialer string 62741675
dialer-group 1
ppp multilink
interface FastEthernet0
ip address 203.92.x.x.x.255.248
speed auto
ip classless
IP cef
ip route 0.0.0.0 0.0.0.0 BRI0
Ip route 0.0.0.0 0.0.0.0 BRI1
ip route 203.92.x.x.x.255.248 203.92.74.234
no ip http server
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password xxxx
login
Thank you for your time!
5 Replies 5
mahmoodmkl
Level 7
Level 7
HI
Looking at u r config i think u r missing the authentication part and username password commands.
Mahmood
Hi there
R u sure about that? cause i have check with Service provider a number of time and they keep saying i dont need that. please advice thank!
BTW i discover that when i send a trace route from to a public server in the Internet, I realised the route keep looping on the fastethernet0 interface
You will need to have authentication in-placed as to authenticate that you are the right party. Your ISP should have the routers and you should use the hostname of their routers as username.
Either:
a) it can be dial-up from the ISP,you will use dialer-map.
b) both way authentications.
c) any others that I dun know?
If not, everybody will be able to dial-up the ISDN numbers and use it.
Please rate the post if helpful.
thanks,
ken L.
nbhandarkar
The ppp authentication chap is missing from Bri0 and Bri1 interface.
Your query regarding the traceroute output looping to your fa interface, u will need to check/inspect the routing table.
