isdn loop question??
andyc2002
Sir
when I use isdn to my backup line on router,and finish to setup isdn configuration,and try to connect isdn,I find can't connect isdn,and I find this messege below..
BRI0/0 is up, line protocol is up (spoofing)
BRI0/0:1 is up, line protocol is down (looped)
my question is why bri0/0:1 will show looped,is the ISP problem or my isdn conf is wrong?
here is my isdn config
interface BRI0/0
description ISDN NO:04-8111-193
bandwidth 128
ip unnumbered Loopback0
ip access-group 109 out
no ip directed-broadcast
encapsulation ppp
no ip mroute-cache
dialer idle-timeout 180
dialer string 0422109152
dialer string 0422109138
dialer string 0281711953
dialer string 0281711942
dialer load-threshold 160 either
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
ppp multilink
7 Replies 7
sourabhagarwal
Level 4
Level 4
you have used "dialer load-threshold 160 either " command which means that second B channel will be triggered only when inbound or outbound load on first B channel is more than approx 63%, due to which I feel you are observing second B channel as looped.
you said that you are configuring ISDn as backup. what is the primary link config? can you post config of your router?
Sir
here is my serial interface conf
interface Serial0/0
bandwidth 512
backup interface BRI0/0
ip address 172.16.20.174 255.255.255.252
encapsulation ppp
no ip mroute-cache
priority-group 1
traffic-shape group 103 144000 148000 152000 1000
traffic-shape group 102 128000 132000 136000 1000
traffic-shape group 101 224000 228000 232000 1000
could you post the output from the commands 'show isdn status' and 'show int bri0/0'? Looped could be a telco issue.
can you share complete output of show interface bri0/0, show interface bri0/0:1 and show isdn status?
if primary link goes down, is traffic shifting to backup link or not?
sir
here is bri 0/0:1 and isdn status
bri0/0:1
BRI0/0:1 is administratively down, line protocol is down
Hardware is PQUICC BRI
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation PPP, loopback not set, keepalive set (10 sec)
LCP Closed, multilink Closed
Closed: IPCP, CDPCP
Last input 01:12:50, output 01:12:50, output hang never
Last clearing of "show interface" counters 16:31:45
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
1654 packets input, 37327 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1654 packets output, 37327 bytes, 0 underruns
151 carrier transitions
isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Activated dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 30, L2D_Task Discards = 29
please attend to it is none isdn dialup status.
BRI0/0:1 is administratively down. You need to do "no shut" the interface. once done check the interface status and see if it works.
if not, please paste the output of interface and isdn status again.
hope it helps ...
From the output which you have pasted i feel your ISDN interface is shut make sure that your giving no shut command under the main physical bri interface to make it up..
regds
