isdn status uptime
Gerard Gacusan
How to determine if the isdn line status has been up for x hours? or it went down for past x hours? is there any show command for this?
i'm looking also somewhere in show controller t1.
the only thing i'm curious is this in "Show controller t1" ... any idea?
Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
thank you...
Giuseppe Larosa
Hello Ggbmsol2004,
show isdn history
can give the details of last ISDN calls
show isdn status
tells you current ISDN status
show controller t1 gives details about OSI layer1 for example if there are errors on the line, but it is not aware of ISDN activity.
Hope to help
Giuseppe
thanks for the reply.
so, we can't tell exactly if layer-1 wnet down from past x days via show commands? correct? yeah, i'm aware of the show isdn status command.
unless some logging or snmp traps trigger to a management server.
paolo bevilacqua
If you do "show controllers t1 serial x/y/z", it will give detailed statistics for the last 24 hours.
