ISR 4221 can't enter global configuration mode
tbyers0
I just purchased four brand new ISR4221 routers as part of an Academy lab set up. I can get them to boot fine, can enter user exec mode and privileged exec mode. However, when I try and enter global configuration mode, I get a command not supported error message. I also get that message if I issue a copy run start or erase startup config command. I am stuck at this point. I have worked with Cisco routers for 20 years and have never had any of them act this way. I have searched the blogs and the internet and cannot find a solution. Any ideas would be greatly appreciated.
39 Replies 39
Hello!
Could you share the updated link?
Hola!
Podrías actualizar link pls!
Link expired please share another link
I had the same problem with an ISR 4221. What i did and work is the following:
Enter Rommon and Change the config-register vlaue to 0x0 to ignore the boot variable configured in startup config
rommon 1 > confreg 0x0
 After that i did a reset
rommon 2 > reset
This will bring router into ROMMON mode once again. Now change the config-register value to 0x2102
rommon 3 > confreg 0x2102
and next i had the actual IOS.bin on a usb and boot from usb
rommon 4 > boot bootusbo:isr4400-universalk9_ias.16.09.02.SPA.bin
 Router booted with that image and then i was able to enter global configuration mode and change the boot. Copy the ios image on Flash from usb and then change the boot
ROUTER(config)#boot system flash bootflash:isr4400-universalk9_ias.16.09.02.SPA.bin
 After that save by issuing
ROUTER#wr
 Once the router restarts you will see that it loaded the new ios image and everything will work as should.
Hope it helps
Thanks for the description of how you got it to work. This may be helpful to other participants in the community.
Rick
Rick
I'm still having difficult with gaining access to a 4221 router. I have upgraded to IOS as directed above, and when booting for the first time I can get to privileged exec mode etc., but if I reboot I am challenged for a username and password.  When I try the defaults of admin admin, I am getting a %Login invalid message.  Am I missing a step that will allow me to either set these credentials or disable them?  IOS used is isr4200-universalk9_ias.16.09.06.SPA.bin
If I am understanding correctly after initial boot up you were able to access privilege mode. But after a reboot you are no longer able to access privilege mode. You are prompted for a user name and password but the default no longer works. I believe that some versions of code on certain platforms implement a single use ID and password. When you login there is a message indicating that you should configure a new user ID and password, and after that initial session the default ID no longer works. I am guessing that you did not configure a new ID and password. If that is the case then I believe that you will need to use the password recovery procedure for this router.
Rick
Hi Rick,  I now have a solution, and that is to use an earlier version of the IOS (16.06.08) as suggested elsewhere.  This version lets me login more than once and reconfigure.  I tried the password recovery procedure procedure but this only appears to work on the privileged exec password not the router ID and password.  I'm sure I set an ID and password initially ('cisco' and 'cisco' as it is for lab use only) but it never seemed to be accepted.
Ian
Ian
Thanks for the update. Glad to know that you have a solution. I am a bit surprised that a different version of code provides the solution. And surprised at this " the password recovery procedure procedure but this only appears to work on the privileged exec password not the router ID and password." I would expect that the password recovery procedure would have addressed both. But as long as you now have a solution that works the other things do not matter.
Rick
We bought 10 of these 4221 routers for our Cisco Networking Academy and they were all locked up like this.  Your instructions worked perfectly for me and I was able to upgrade them to 16.12.04.
You can check my reply from 12/3/2019. That's what i did and manage to solve the problem. Hope it helps you.
Ihor Zaitsev
Just type:
controller mode disable
and answer "confirm" twice.
manuabra
I am using ISR4400, after booting with IOS-XE, I still had the issue, below commands worked for me.
Router#controller-mode disable
Disabling controller mode will erase the nvram filesystem, remove all configuration files, and reload the box!
Ensure the BOOT variable points to a valid image
Continue? [confirm]
% Warning: Bootstrap config file needed for Day-0 boot is missing
Do you want to abort? (yes/[no]): yes
Router#
not a valid command on a 4221
We bought 104 of these to replace older 2911's when Cisco went to v7 - - and they have been nothing but a PITA - - wish we would have never changed.
Even with some of the earlier recommendations - we would still have routers randomly boot back into sd-wan mode.
Here is what I finally did that seems to stick;
Have a USB stick (with a 4gb partition as FAT32) and the IOS you want to use (I downgraded to 16.9.4)
Boot normally.
If it comes up in sd-wan mode (asks for login account) - use  admin / admin
router# pnpa service discovery stop
router# copy usb0:isr4200-universalk9_ias.16.09.04.SPA.bin bootflash:
router# config-transaction
router(config)# config-register 0x0
router(config)# commit
router(config)# end
router# reload
rommon 1> dir bootflash (to make sure the file you copied earlier is being seen)
rommon 2> boot bootflash:isr4200-universalk9_ias.16.09.04.SPA.bin
router# config terminal
router(config)# config-register 0x2102
router(config)# end
router# wr
