ISR 4221 can't enter global configuration mode
tbyers0
I just purchased four brand new ISR4221 routers as part of an Academy lab set up. I can get them to boot fine, can enter user exec mode and privileged exec mode. However, when I try and enter global configuration mode, I get a command not supported error message. I also get that message if I issue a copy run start or erase startup config command. I am stuck at this point. I have worked with Cisco routers for 20 years and have never had any of them act this way. I have searched the blogs and the internet and cannot find a solution. Any ideas would be greatly appreciated.
39 Replies 39
Thanks for the update. Thanks for sharing the solution that works for you.
Rick
mnael.aljabri
I had the same problem also and found that the router has a SD--WAN image try this command in enable mode:
controller mode disable
and answer "confirm" twice.
After reload the router you should able to enter the configuration mode
BR
Nael
Nael
Thanks for sharing your experience with this problem. Several earlier posts in this discussion have identified the issue of an SD WAN image and access to config mode. Did your experience with controller mode disable also involve a new image (standard image) or are you still using the original (SD-WAN) image?
Rick
I ended up replacing the IOS image on all ours.
Hi Richard,
after disabling controller mode i could entering the configuration mode and i replaced the image by using standard one
Nael
Nael
Thank you for confirming that your solution was both disabling controller mode and running a standard IOS image.
Rick
Rick,
our task were to change the SD-WAN image on the router to standard IOS image to do that i was not able to going in the configuration mode with the SD-WAN image. When i type „configuration terminal“ got an error message this command isn’t supported. So in this case i have disabled the controller mode with the command „ controller mode disable „ then hit enter twice and reload the router. After that i could go normally in configuration mode and change the IOS version to standard one as requested.
Nael
Nael
Thanks for the additional explanation.
Rick
claude.karemera
Hello Kumar,
I am facing the same issue... can you please help me to share the image.
hello team,
anyone with the image?... please share it... I have cisco ISR4221 and is currently running with SD-WAN image.
